Kalpa_V
Kalpa_V's Achievements
  1. Idle with AC on : 700 to 800 Idle without AC : 600 to 700 Gear shifting is normal no lag between gears and i didn't notice any difference. only thing i'm worrying about is this starting issue. Anyway, i thought to take this to agents again for a Engine Tuneup, And i know they will charge a lot But i thought it ll be much safer to go there rather than going to a local garage.
  2. Yes, When i buy, car came with 4 original Dunlop tires (Dunlop SP2030 japan) and tire manufacturing year also 2008. 1. This is an "U" grade, and this has RPM meter and all the other options as well. 2. Yes i observed this very recently and even today morning when i start the car it starts normally but stopped just after started. Then i hear sound like a motor is working (seams to be fuel pump not sure, and car is in Ignition ON state) and then i start again, it starts normally. 3.No i didn't remove battery after i buy this car. But previous owner had change the battery to a new one.
  3. Yes, but i checked with all the past records and it seems to be true. i got Japanese service records, JAAI and even agent inspection report when i bought.
  4. Hi All, I have a toyota Vitz - KSP 90 (1KR - 1000cc) and it had only 29000km in mailage. Manufacturing year 2008. As per previous owner confirm it had 13000km when he bought as unregistered and he did only 6000km for past one year.(Vehicle is registered in 2013 September and i bought in 2015), After he bought he done Engine Tuneup and first service from agents. Now i face following issues. 1. Car does not start at once after 7 or 8 hours stop - Crank several times before start. I check battery also, it s good and i tried to turning ignition ON, wait for few sec and then start. That worked most of the times. Car starts without any delay. Is this Normal in vitz ?? 2. RPM goes around 2000 when i stop in traffic in N position - RPM goes to 2000 from idle and came back, this recently happen few times to me and it happens when AC is on. Do i need to do an engine tune up again and please mention any good places for that in Colombo. Kindly looking for some advises on this from you guys. Regards, Kalpa.
