Abbas
Gender
Abbas's Achievements
Anyone Done A 4M40 Conversion On A Montero V75?
Abbas replied to Abbas's topic in General Automotive
Priyanka where can you get the bell housing fabricated here. And will the engine mount without any hassle. I have seen many 4m40 conversion but all of them have used the existing gearbox. Sorry for the trouble. -
Yes from what I have seen the original 4m40 diesel montero is electronic diesel pump and the the japan domestic models are manual diesel pumps.hence the montero diesel 4m40 is smoother engine . It's basically same as the 4m41 but in this case it's a 2.8L manual. Does anyone know if the 4m40 engine will mount without any modifications. Also how do you connect the exsisiting gear box on to the 4m40 engine. -
Thank you priyanka.i had also done the 4m41 previously and it was a success. I was wondering about the 4m40 bec its a much cheaper conversion. Thank you for the input. Great help. -
I already did. Dint find anything on 4m40.sorry for the trouble. -
i need some advise.i have seen many montero's converted using 4m40 insted of the 4m41 engine.can someone give me advise on the the 4m40 conversion.
Thank you.
- 3 replies
- Conversion of vehicle class
- rmv
(and 2 more)
Hi .I need some help.i called the rmv but dint get a proper answer. I recently purchased a toyota single cab registered with" L " number plate under motor lorry.now I want to convert this to a dual purpose.i kw in the past the rmv was doing this for a charge of arouns Rs.40000/=but since of late it has changed and i would like to know any members in this form have had recently done this and have any idea how much would this cost. Any information will be greatly appreciated.
- 3 replies
- rmv
(and 2 more)
i have PM you @ awsome.
Hi their, You can buy a completed original diesel kit for the montero . its the 4m41 3.2 DID kit.this comes with the engine and gear box , computer boxes , wire harness ,silencer kit,cluster meter,diesel tank , basically a entire montero with out the body and will cost u around 1.2million. Hope this helps .i have seen a few done and its good as original bec its just a plug in original kit and has no difference from a original montero.i have seen one on the AL classifieds for sale in this site.
thanks bro !! my jeep roof is full of dents . do you know a exact place to buy a heat gun will be really help full?
Hi ! It's actually a very simple thing! Near ur rear (decky) boot door u get two pressure releasing vents! When these vents get covered or stuck ur vehicle air inside has no place to go! That the reason when u leave ur shutter or front door open the rear door closes easily.u will need to find those vents located near the rear boot door ! It's normally located on the inside on the top of the rear boot door.check and see if the flap has got stuck or covered.u will need to take the side pannel of the rear to reach this ! So i advise u to get help of a person who has experience a bit.hope this helps.
The legal RMV charge is Rs.38000/= for registration . just keep Rs.55000/= for everything bec you have to make the guys inside happy lol better you get hold of a person in the RMV other wise you will waste a lot of time and get rastiyadu fied. according to the new system they will print diesel converted on your book and issue new number plates with the letter D printed under the plate. for older vehicles with 301 series numbers just the mention on the book and that about it. If you like to confirm just call Over the Rmv they will guide you. the documents needed are:- 1.Original book 2.original v.i.c 3.identity card copy of registered owner. 4.original license 5.original insurance 6.02x colour photographs 7.all luxury tax receipts Remember if you have a lease on yor vehicle you have to get written permission form the leasing company but am not sure if it would be allowed and am not too sure about it.
jdnet, i think the engine price is reasonable being toyota engines high demand specially as many noah petrol vehicle owners convert their vans with this engine to diesel. I will have to tell you the gear box is always best to go with that engine gear box. May be ur mechanic has more knowlege on this matter than me but as harshan senadhir stated before was correct. bec diesel and petrol engines gear boxes have different ratios .see only in the noha and dolphin van to my knowledge so far where the gear box is identical in in both petrol and diesel variants, or in some cases where the manufacture has made the same model of vehicle in both variants. My advice for u is go with the Toyota 3c gear box and u couple the 4wd unit(trasfercase) of the tribute to this. i did that with my montero sport due to the pajero gear box not having the 4wd super select system and it worked fine. Am not a expert on this i am just giving my opinion your mechanic knows his job but just asking him want create a issue. all the best and let us know when you complete your jeep.
no bro all parts are recondition !:)so u have to check before u pay for it!
