ranushka
Everything posted by ranushka
  1. try recondition part
  2. Dont buy recondition shocks . try to repair the shocks. cost 15k only for all 4 shocks. i did last time and no issue up to now
  3. According to my experience and knowledge you can increase ur fuel efficiency by 1-2 km/l by focucing on following things 1. tires use the correct tire size. and air level .good road tires will increase the fuel consumption 2. Petral level on the tank try to keep more than 1/2 full 3. Gear box check the oil level in gear box . change gear oil abt every 25000kms 4. Engine oil . use a qulity engine oil and check the oil levels and change the oil abt every 3000-4000 kms 4 . breaks check the break system and ensure there is no break blinds. 6. belts. and air filter check the condition of belts, air filter and replace if need ( fan, AC and power pump belt) . 7. AC gas level. keep the correct AC gas level in high side 8. silencer. check the silencer for leaks and dont use beat silencers. silencers with leaks will give the wrong figures with the oxygen sensor 9. throttle body all the sensors must work 100% for good pickup and good fuel consumption. specially ideal up sensor. 9. body kits dont use the large body kits for the vehicle its increase the air resist on. body kits will reduce the consumption in long rides.
