Thank you Twin Turbo and Rumesh88
I forgot to mention something i had another carb in garage and swapped them for a test that other carb does exact same thing
Maybe the other one has the same problem as i had played too much with that one too.
Twin Turbo does the coil problem just happens at idle ? should not it have any other symptoms when driving too ?
Rumesh88 i have observed the choke and the cam goes out when it is hot , but there is one gotcha when starting engine cold the choke does not seems to be acting correctly at first the idle is very low after starting to drive the idle gradually starts going up to 1200-300 and remains there for sometime then it starts falling and the main problem as i described starts to happen.
Some how the choke seems to act opposite first it is low then goes up and it took a little long time to comes down again.
I had the choked removed and cleaned .
I used some carb cleaner to check for vacuum leak and could not find anything but i have not checked the brake booster you mentioned , i should check it.can it be a rich condition as i can smell fuel from exhaust clearly ? or maybe lean ?
One another point which is little hard to explain , when im in parking ramp which is steep the same things starts to happen and car starts surging very badly i doubted may be its float and needle but i have changed them anyway.
Best regards
