Nadee7
Everything posted by Nadee7
  1. Yes.Right side H4 & Left H1.H1 socket is smaller than H4 socket.im i correct?? Cant fix H1 bulb to H4 socket. I changed H1 bulb recently cost 2000 rupees. it's rare model.
  2. There is a issue also.My left side bulb is H1.Its not fit to H4 bulb housing.
  3. Advice please... I have an small issue.My car right side head bulb (H4) when its dim mode very yellowish but when its head mode very bright. I want to know issue is with bulb or reflector.I have clean the front of plastic light.(Cut & polish) Thanks.
  4. Hi all, Final update.I replaced my water pump genuine Nissan.Now issue is ok. Cost 8000/- with labor cost. Thanks all. Cheers.
  5. Dear all, Finally i decided to replace my water pump.I want to know small thing, are they drain fully coolant in radiator to replace the water pump? Bcos i changed new coolant on 3months ago. Thank you.
  6. Actually Im changing only front parking , interior doom light & number plate only Thanks for your advice.
  7. Actually Im changing only front parking interior doom light & number plate. Thanks for your advice.
  8. I need your valuable advice ,I'm going to change my existing tail lights,Number plate light & interior doom light to white color LED Lights. Is it normal or do i need to do some wire change ? I have attached a sample . Thank you.
  9. Dear all, I'm going to replace my front break pads.So can you tell me what is the best from the following list. 1.FBK 2.FBL - Japan 3.NIBK- Japan
  10. I want to change my gear box oil.Currently its having Caltex texamatic 1888 oil. So I want to know that oil is good or do i need to go for a new oil.Gear box is not CVT. Your valuable advice are highly appreciated.
  11. Last week i went my garage & mechanic said if water pump goes continuously water leaking from the pump.I did the test run also but no visible water leaks.Finally he said we will wait & see.So i came back. I don't no really confused .
  12. How to find whether its genuine or not ? is there any logo ?
  13. Ok Noted.Thank you.Any warranty available for genuine water pump ?
  14. Do you know any reputed shop to get genuine part ?Around Kadawatha,Gampaha,Kiribathgoda?My mechanic said new water pump coming from made in taiwan.so he recommended japan used one. What is genuine GMB ?My Engine is QG15.
  15. How to find genuine pump ?How japan recondition pump ? How much it will cost ???
  16. I checked water pump area & pulley also.But no visible coolant leak.But there are some coolant spreading on & often. Can i repair water pump ? or do i need to replace if it gone ?
  17. I replaced a new cap also.This issue is coming only on & often .I checked heat hose line & cold hose lines.All are ok.
  18. Yes .Filled to Max level only.
  19. Dear All, I need your valuable advice .Im using 2003 N16 FG10 Sylphy.Recently i noticed there is a low coolant level in coolant tank & there is a little bit coolant in Drive belts. Recently i changed genuine belts.Heat level also normal no over heat no water drop in radiator.Only coolant tank water level going down.What is the issue ? This is not daily happen .On & often only. millage is KM198000 genuine .
