Niwantha2007
Niwantha2007's Achievements
  1. thank you Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
  2. thank you Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
  3. I have BJ3P Mazda car and it start blinking hold sign while drive the car what shall I do.. Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
  4. What is the Recomonded octane value for the Mazda familia BJ3P 1300cc car Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
  5. I did change ignition arm but same result. Finally I send car to the Mazda work shop and they have changed the petrol pump and the air hose and problem solved. Tank you verymuch . Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
  6. Thanks, there are cracks in rotor arm and I am planning to check with new rotor arm , rotor cup & wires. and I have another clue when engine temparatue saturate mis is getting worst but when high rpm is getting better
  7. I newly brought this car, I don't have history. and when the idling there is mis and suddenly nock is coming.and when the accelarating mute the engine. I doubt whether it is distributor, because why only third cylinder not function. How about, test the compressure
  8. thanks, I did engine tuneup & checked wires too. Technician said that the third cylinder not function. and I verify this eith another technician. both confirm that hole distributor should replace.
  9. it is ok used one.
  10. Car model is Mazda Familia, 2001 BJ3P 1300cc
  11. hi I have BJ3P 2001 and there is problem in distriburor .Any place to buy it and how much I need to spent
