nuwanjjs
nuwanjjs's Achievements
  1. i have allion 2007 and it has done around 116,000km. I m second owner according to the service full service needs to be done every 40,000km. What are the things need to be done and how much will be the cost for such service?
  2. Yes. only on first gear. i scanned gear shifting by connecting scanner and it seems ok. but when car is stop and then i accelerate rpm goes up to 2 but car is moving slowly. once gear is shifted second, it seems ok. its only done 30000km since last gear oil change
  3. how much will be the genuine cvt oil??
  4. Yes I have complete records and they have changed cvt oil at every 40000km and engine tune up is also done according to the records.plugs are also fine. According to my friend i needs to check cvt oil and do a engine tune up. I guess i should start from that. Is it ok? He also said me that it will solve vibration issue also. I
  5. 260. At the first gear when i accelerate rpm will go up but car is moving slowly. And there is little vibration. I did a scan yesterday but gear shifting seems ok. Will this problem solved from tune up and transmission fluid. One of my friend this scan and he told me once we do proper tune up and change transmission fluid this will be ok kiyala.
  6. All the services has been done from toyota lanka. Service that needs to be done from every 40,000km is also done. I believe that ATF will be changed at full service in ever 40,000km.I don't know how to check this. Is there any good place. Since this is my first car I do not have any idea about that.
  7. I have allion 2007 done about 110km. I recently bought this vehicle and i m experiencing pick up issue in this car. Recently one of my friend told me my car has a pickup problem? I also experienced this because when i accelerate the vehicle even though rpm goes up to 3 vehicle doesn't will speed up after few seconds. Full service which needs to be done at 120,000km. What is the problem with this car and what should i do?
  8. is it ok to change rim size as per this? https://www.tacomaworld.com/tirecalc?tires=185-70r14-185-65r15 185/70/14 to 185/65/15 vehicle allion 2007
