hiranp
Everything posted by hiranp
  1. Air filter was replaced couple of years ago. Took the Echo test only couple of weeks ago passed with very good readings
  2. 1.Before pressing the accelerator it is at a lower RPM. 2.AC system is not working.3.Location Malabe. TNKS
  3. when the accelerator is pressed and released ,the engine is kept raised at idle without slowing down, and on motion after engaging gears the vehicle moves without the need to press the accelerator. i.e vehicle needs only the use of the clutch and the break pedal. Showed it to a mechanic and his advice is that the fault lies in the `door` of the carburator and not in the accelerator cable. your advice together with a recommendation of a garage where I can sought out this problem is very much appreciated
