Hi Guys,
I'm having the same problem with my FD1 when driving over 100. During the last service at the agent. I asked them to look upon to it and check wheel balancing and stuff as well. And they showed me that there is 10 degrees angle out in the front right side ( ideally it should be within 0 - 30 range. But it was 40 degrees ). They didn't tell me anything about brake pads or disks. But adviced me to replace the knuckle which costs at the agent around 43K.
I was going to do it, but then again I got to know it can be fixed from some wheel alignment shops ( by pulling the knuckle or something that I am unaware of ). Today I went to C*r *Ca*e to get an idea on that. And they said that can be done using a puller. But if the pulling range is higher, they said there is a tiny chance it might affect the shock absorber.
My concern is, does anyone have any experience with this puller mechanism? Will that add any unwanted side effects?
And also if I am to get the knuckle replaced, can you please suggest any recommendation :).
Thanks in advance
