Vanette c22
Everything posted by Vanette c22
  1. Thank you for your contacts, i’ll find a good one! ☺️☺️☺️☺️☺️☺️☺️☺️☺️☺️☺️☺️
  2. Exactly as your b310 carburetor my one has vacuum lines working but slow jet and electric choke not working, when idling its not smooth rpm increases and decreases all of sudden and idle also too rough. And fuel also burning when adjusting the mixture screw to just one round from full tight make this happen. 🙄🙄🙄 replaced the petrol jet to 85 but vehicle is hesitated to accelerate, now it has 90 sized one installed, nowadays can’t drive the vehicle as it jerks while on move and suddenly engine dies too. If there any trusted place that you know to purchase a good reconditioned carb is very useful! thank you!
  3. Hi anyone here please help me to find a good carburetor to my vehicle 😞😞😞😞😞😞😞😞😞😞😞😞 I’m attaching the current carb picture please find me a good one 🙁
  4. Thank you for your information, carburetor was refurbished using repair kit but it's always end up in something failing. Thats the reason I'm looking for a new carburetor. vacuums are not working as expected and always gives problem with vehicle idle.
  5. Hey everyone! i need a place or person to buy me a reconditioned or new carburetor for my vanette c22 (A15) Have a question about online purchasing the carburetor, as an individual can i purchase it from ebay or aliexpress or some Malaysian or japan e commerce sites?
  6. I’m experiencing an sudden engine stop while on run, so i checked with mechanic and got to know that alternator won’t charge the battery.. recently alternator got serviced and was running fine. Day before yesterday when i was on run again same problem came up.. now I’m confused what can be the actual cause??? ??? As I’m a learner on vehicle mechanisms please some one explain me why this is happening!! i have checked and changed all the electronic parts which are; * distributor serviced and platinum point replaced * new bottle coil replaced (which they recommend is original for this vehicle) * new ngk plugs * engine timing checked * alternator serviced Engine has a carburetor which is in running condition and other electrical equipment all checked. still I can’t find out why this is happening ? all of a sudden van getting stop, after few minutes it starts again runs normal.
  7. Thank you ? Cyclist..
  8. Hey there... i’m here for vanette c22 fuse box diagram, i just checked the fuse box I couldn’t get it right, as it showing numbers 1 to 20 and one side is on other is just off.. ?? if anyone could explain me the diagram clearly would be a great help!! Thank you.. i’m attaching picture of fusebox here ??
  9. Hi, after long days of search i just find out that my van problem is with carburetor, actually there are vacuum leaks, throttle shaft is the culprit. Now I’m searching for a reliable place to repair this issue.. please suggest me a professional place to fix this out because local mechanics don’t have the idea of vacuum system. Is there any place in kandy or near by to resolve this?? It's hard to drive the vehicle on road with this issue?
  10. Hi there.. anyone tell me a good place to buy Nissan A15 engine's original carbulator??
  11. Hey there.. need a good place to check my van. Engine sound is not that good. Time to overhaul the engine i guess.. recommend me a good place please. Is there any nissan service ponits available??
  12. Uhhh.... hmm..... then replacing both arm would be good i guess. Thank you
  13. Guys.. my wiper arm spring got damaged today ? local auto motors or reconditioned shops doesn't have the tension spring.. they say i need to replace the arm itself ? Any ideas??
  14. ☺️
  15. Thank you man it means alot.. if there any place i can find a service manual for c22?? I need to fix the blower switch on the dash board which is not functioning
  16. #Twin turbo what do u mean by aijr filter??
  17. I must tell one thing i used to tune my van from a local man who is good with petrol vehicle.(now im not ok with this guy) When i cold start the engine, can see water coming out of exhaust! But i feel lack of power of an 1500cc engine. I have to paddle nearly half to make the van moving (i used to switch gears 1st to 2nd at 20kmph then 3rd at 40km nd 4th on 50km) when vehicle is on 3rd gear have to paddle the gas hard to make small gaps. Talking about fuel consumption per L it does 10km and on long run 13km. On drive, engine noise also very annoying ?
  18. Davy, thank you for the details.. and i need further information on improper ignition timing??? Can you detail me? And here in nuwaraeliya its hard to find a one who can tune petrol engine. Can you recommend me a good place??
  19. Hi everyone, my vanette has a problem with eco test, it fails on HC! On idel van Hc reading goes to 2300 but on rpm Hc reading is under 1000. CO is passed on both ideal and rpm. Now what should i do??
