2CE
Everything posted by 2CE
  1. 2CE
    Toyota corolla diagnostic
    Beauty of this model car is that you don"t need a scanner at all to scan this . can do a manual scanning. Retrieving the trouble codes on your OBD I Toyota Corolla isn't difficult. In this tutorial I'll explain how you can do it in a step-by-step way. Checking to see what trouble code is lighting up the check engine light (malfunction indicator light -MIL) is done by jumpering together the TE1 and E1 terminals of the Data Link Connector (DLC) with a jumper wire (with the Key On Engine Off). Once the jumper wire is installed, the malfunction indicator light (MIL) will start flashing the trouble codes stored in the fuel injection computer's memory. Contents of this tutorial: · Reading The On/Off Flashes Of The Check Engine Light. · Location Of The Diagnostic Link Connector (DLC). · Toyota OBD I Diagnostic Trouble Code Definitions. You can find this tutorial in Spanish here: Cómo Leer Los Códigos OBD I (1990-1995 1.6L Toyota Corolla) (at: autotecnico-online.com). Reading The On/Off Flashes Of The Check Engine Light As mentioned at the beginning, your OBD I Toyota Corolla flashes the malfunction indicator light (MIL -also known as the check engine light CEL) once you have jumpered terminals TE1 and E1 in the diagnostic link connector (DLC). The DLC is located on the left strut tower in the engine compartment. To see a photo of the DLC, go to: · Location Of The Diagnostic Link Connector (DLC)). These are the steps to retrieve the trouble codes: 1. Make sure your battery is fully charged before starting (its customary to place a charger on the battery while retrieving trouble codes to keep the battery from discharging). 2. Turn the key to the On position but don't start the vehicle. 3. Jumper terminals TE1 and E1 of the diagnostic link connector in the engine compartment. 4. Count the number of flashes of the malfunction indicator light (MIL). 5. If no trouble codes are present: · The MIL will flash continuously and evenly (see illustration below). 6. If trouble codes are present: · The MIL will flash the trouble codes in a specific pattern. · The digits of the trouble code will be flashed at about 1/2 (.5) second intervals. A 1 1/2 (1.5) second pause will separate first and second digits of the code (see illustration above). · If more than one trouble code is stored, a 2 1/2 (2.5) second pause will separate the next flashed trouble code. · Once all trouble codes are flashed. a 4 1/2 (4.5) second pause will occur. After this 4.5 second pause, the trouble codes will be repeated. · Trouble codes are flashed in order of smallest to largest number. Once you've confirmed and written down the trouble codes, remove the jumper wire from the diagnostic link connector (DLC) and turn the key to the Off position. Location Of The Diagnostic Link Connector (DLC) The diagnostic link connector (DLC) on your Toyota Corolla is located in the engine compartment. More specifically, it's attached to the left-side strut tower (see image above). Toyota OBD I Diagnostic Trouble Code Definitions 1990, 1991, 1992, 1993, 1994, 1995 EFI Toyota Corolla OBD I Trouble Code Definitions Code Description 11 ECU Battery Power Malfunction 12 G and NE Signal Circuit (No. 1) -RPM Signal Problem 13 G and NE Signal Circuit (No. 2) -RPM Signal Problem 14 Ignition Signal Circuit 21 Oxygen Sensor Circuit 22 Coolant Temp Sensor Circuit 24 Intake Air Temp Sensor Circuit 25 Air/Fuel Ratio Lean Malfunction 26 Air/Fuel Ratio Rich Malfunction 27 Sub-Oxygen Sensor Circuit (California Only) 31 Manifold Absolute Pressure (MAP) Sensor Circuit (MAP Sensor Equipped) 31 Air Flow Meter Sensor Circuit (MAF Sensor Equipped) 41 Throttle Position Sensor (TPS) Circuit Malfunction 42 Vehicle Speed Sensor (VSS) Signal Circuit 43 Starter Signal Circuit 51 Switch Condition Signal Circuit 52 Knock Sensor Signal Malfunction 53 Knock Control in ECU Fault 71 EGR System Malfunction 72 Fuel Cut Solenoid Signal Malfunction
  2. I have toyota corolla CE110 DX, milage 200000Km. recently noticed an engine vibration when come to a halt on traffic. vibration reduces when putting to Neutral gear. what can be the issue. recently changed all engine mounts with genuine parts and there wasn't any vibration issue those days. can this be due to bad injectors or injector pump issue. not touched the injectors or the fuel pump for a long time.
  3. Thanks for the reply. any way you know how to find a repair manuals. even if it is in JAP is OK.
  4. does any one have a repair manual for this 2C engine how to check the vacuum system ?
