ashan.de.alwis
Everything posted by ashan.de.alwis
  1. I see, in that case its mainly due to the road conditions especially potholes. Mine has done around 6500 KM's. And the noise started around 5000 Km's.
  2. Thank you i will look into it.
  3. Thank you for the prompt reply, Just wanted to check whether anyone had both the squeeks and rattles at the same time and if they're related to eathother. I will have a look and if there are any developments i will update.
  4. Hi guys my suzuki swift started making rattle sounds from the front driver side (sound comes from underneath more like from the rack) when going over bumpy roads and there is no sound when driving on smooth roads. Also there is a rubber squeeking noise when turning the steering wheel from the center, sounds like rubbing on rubber. It is more noticeable when you drive a fair distance and when the engine is warm. I have attached the link for two short videos of the noises: https://drive.google.com/folderview?id=1CIcWsxez7ZYbNpazTndgTuRFdQQFzf0I (You might have to use earphones for the rattle noise video because it is quite hard to notice) Is this a known issue for Suzuki Swift's? If anyone has the same problem and have already solved it please let me know. Your help is much appreciated. Thanks
