Boeing747
Boeing747's Achievements
  1. Apart from Panchikawatta, In Delkanda there are few places as well. (Api Singhe Motors/ Ichiro Motoring/ Lapan Lanka etc.. The place mentioned by Davi also has lot of parts but his prices are somewhat expensive.
  2. Interesting Post. Yes the current prices are absurd indeed.
  3. Going through the thread i learnt that the ride comfort could be improved using Bridgestone ecopia or dunlop sp touring r1. Can some one share about the DUNLOP In terms of ride comfort and road noise. regards
  4. Yes. Popular Belief is the other way around.
  5. I was going through this interesting thread. and below part contradicts what i read . Fastresponse (Japan) - Tread Still looking good after 61ks and might go all the way to 80-100ks. I am quite scared to have them at the front as they are not that sure footed as the EP200s. This is very apparent when making a U turn in a gravelly area, the car would just slip and slide without much control at full lock, and I generally drive much slower when the service guys rotate tyres. In case changing only a single pair of Tyre's the newer pair should be fixed in the rear right ?
  6. Thank you for all your responses gentlemen. Hello Mazdaspeed. It is a Sedan and millage is 145k ( But i always doubt the SL millage as it could have been tampered somewhere before the timeline.) Previous owner only mentioned that he used Mobil so that's why thought of selecting one.So what would you suggest . and some more info about the ride. engine 1,490cc ,2wheel drive , tiptronic Transmission I'm hoping to do all the mechanical maintenance stuff relevant started with Full Service . 2. ATF oil change 3. Suspension check up. - The vehicle has hard suspension which i'm not used to. Handling is very good when traveling long distance. But when going on a bad road ride is very bumpy so i'm wondering whether it is because the hard suspension or whether i should change the shocks and check other components.
  7. Hi, I have recently bough Mazda Familia RS Special Edition vehicle. I have done a full service and hoping to do ATF oil change as well. Please help me to select between the below three types to use for the Tiptronic Transmission. If possible kindly explain the difference as well. 1) 800 × 800 2) 640 × 700 3) 222 × 400
