Alfa159
Alfa159's Achievements
  1. Same issue happened to me but only right turn signal flashes fast, checked the bulb which isn't blinking but its not blown too. Removed the flasher relay and checked with test light the relay clicks faster. Flasher relay was closer to the center console next to the steering column shaft fixed on a metal L mount bit deep inside and not with the usual fuse box. Had to remove the panel under the steering for easy access (Nissan Bluebird SU14)
  2. Hi I need to replace two tires for (Nissan Bluebird Diesel - 185/70 R14) since tire is 10 years old and one of the tire is cracked on the inner side. Also i want to know about warranty period since two different places gave different time periods (2 Years and 5 Years). SONAR (Taiwan) Tyre is 3 years with 60,000 kms warranty and mentions softer/comfortable than NANKANG Any user experience with SONAR / NANKANG / KAPSEN / ROYAL BLACK / LASSA Tyre brands Thank You.
  3. Alfa159
    Replace Car Battery
    Managed to use EXIDE for almost 4 years on Nissan Bluebird (Diesel) which wasn't a daily runner too.. Also got 3 times of jump start from Browns mobile service for FREE !!
  4. Hi, i m having difficulties reading at the ODO LCD Display reading at day time due to more light and blurry display (at night time will be able to manage to read the ODO reading). No idea how it happened since it was the same when bought it. All the other gauges are working fine in the speedometer. any suggestions to repair this ? Thanks
  5. Any BMW X5 xDrive40e Plug in Hybrid (F15) users and is there any hybrid related or other known electrical issues ? And any Audi Q7 (4M) users
