Jeeva Renganathan
Jeeva Renganathan's Achievements
  1. If you feel it is sharing even after the wheel balancing then, check your inner CV joint in the Axle.. Also check the Break Disc status, whether it is warped ...
  2. I took the Panoramic Split roof out of the body and found out, a seal that is in between the Panoramic Split roof and the body is perished... this the cause.. We cleaned the body and the Panoramic Split roof, and we will fix it tomorrow.. we need to remove all the soft upholstering to get the roof off the body..
  3. The issue is there is no Drainage Pipe down, but the water meant to be draining down the windscreen edge beading (Garnish). but some reason through the four corners it is leaking. So i am going to remove the Sun roof to see the condition of the body underneath the Sunroof railing. Then will take pictures and inform you.. Shops in Malaysia has done this repair and they are not revealing the method. but i will DIY and see..
  4. The issue is there is no Drainage Pipe down, but the water meant to be draining down the windscreen edge beading (Garnish). but some reason through the four corners it is leaking. So i am going to remove the Sun roof to see the condition of the body underneath the Sunroof railing. Then will take pictures and inform you.. Shops in Malaysia has done this repair and they are not revealing the method. but i will DIY and see..
  5. Dear Friends, I have a issue with my Harrier 2008 Panoramic sun roof and it is leaking from all corners and making the car smell bad.. Do you guys know anyone other than Toy#ta L#nka who can repair this or help me with the trouble shooting the same.. I really desperate to find some help asap. regards Jeeva
