athula kumara
athula kumara's Achievements
  • Conversation Starter Rare
  • Week One Done
  • One Month Later
Recent Badges
  1. Hello when running care on the mountain has been mix therefore i was scan my car & indicate two fault 1.crank sensor 2.coli Already replace 3 coil & crank sensor but again re indicate the check engine bulb & mix can you give me the instructions Thanks Br Athula
  2. thanks of your information
  3. Hello Dear See the attached picture in my exsaloon car What do you think those are oil or coolant but no found coolant leakage after start car I checked Ac compressor belt later founded inject green colour water a little time Whta are the think give me the instructions what can I do Thanks Be Athula
  4. Thanks all
  5. Hi, How can I select security system for car We are need to select car modal base security system My car is Exsaloon fb_15 Please help me Thanks
  6. There are more problem about radiator cap of my car 1.colant come in to from radiator cap start the care when cooling fan on why is it? 2.so above reason need to refill coolant data by day
  7. The problem is solved, rechecked with my technician after founded that cooling fans are not working. Reason is the plug of the cooling fan has been burned. Thanks for your advices
  8. i checked with technician he said gasket issues is it correct or no i can't on AC compressor because re not looard gas after added compressor i think cleared my problem to both my head is fire
  9. as of your knowledge both are think so above combinations effected to gasket issues
  10. i have trouble my car 1.after heat mid level in meter up,not automatically on cooling fan 2.when escalator up coolant refill to coolant tank above both combination effect to gasket ? see the attached photos' in this valve very impotent or no
  11. i have trouble my car 1.after heat mid level in meter up,not automatically on cooling fan 2.when escalator up coolant refill to coolant tank above both combination effect to gasket ?
  12. hello i have FB-15 car year 2001-2005 my question is 1.after on ac button come sound cree creee why is it? 2.ac compressor stuck & fire & alternate & ac compressor belt was broken why is it ?
