Hello
when running care on the mountain has been mix therefore i was scan my car & indicate two fault
1.crank sensor
2.coli
Already replace 3 coil & crank sensor but again re indicate the check engine bulb & mix can you give me the instructions
Thanks
Br
Athula
Hello Dear
See the attached picture in my exsaloon car
What do you think those are oil or coolant but no found coolant leakage
after start car I checked Ac compressor belt later founded inject green colour water a little time
Whta are the think give me the instructions what can I do
Thanks
Be
Athula
There are more problem about radiator cap of my car
1.colant come in to from radiator cap start the care when cooling fan on why is it?
2.so above reason need to refill coolant data by day
The problem is solved, rechecked with my technician after founded that cooling fans are not working. Reason is the plug of the cooling fan has been burned.
Thanks for your advices
i checked with technician
he said gasket issues
is it correct or no
i can't on AC compressor because re not looard gas after added compressor
i think cleared my problem to both
my head is fire
i have trouble my car
1.after heat mid level in meter up,not automatically on cooling fan
2.when escalator up coolant refill to coolant tank
above both combination effect to gasket ?
see the attached photos'
in this valve very impotent or no
hello
i have FB-15 car year 2001-2005 my question is
1.after on ac button come sound cree creee why is it?
2.ac compressor stuck & fire & alternate & ac compressor belt was broken why is it ?
