ajwad
Everything posted by ajwad
  1. From where can i get acetone????
  2. Hi Guys, I have been using a suzuki grand vitara 2000 model V6 2.5L auto. recently i have been getting a 'click click' noise from the engine when i start in the morning (cool start) for about a minute and it goes off. When i accelarate the click click noise also accelarates. I use Cas'l gtx 20w-50 oil and i have done about 120000km. Could some one help me out here???
  3. Well guys i had the same problem on my mazda 323. i was confused what to do. finally i got it repaired by Chandana who is an expert in auto gear bow repair in ambuldeniya nugegoda. It cost me 25000/= and 3 months warranty. gave the car in the morning and got it next day afternoon. My o rings/plates/oil and a solvanide was changed(brand new). My problem was solved, but have to use the car for some time and see.
  4. If you are looking for a car for long term and hard use, i reccomend you to go for a MAZDA 323/Familia or Honda EK3/ES8 for your budget. Interior is also nice and hardy. You can also find the leather interior also. Well i have used several cars and i have experiences that these are outstanding. Will recommend to anyone. i think more than the fuel, you should check the durability of car.
  5. ajwad
    Auto Gear
    Hi, Did you do a repair??? where did you do it??? and how long have you been using the car now???
  6. What do you think about repairing the box. I was told to take it to chandana in ambuldeniya. He is an expert????????
  7. ajwad
    Auto Gear
    So are you still using the same repaired one??? I am in a situation to decide what to do. cause if i have to change to a gear box, i have to be lucky to get one which will not give any problem. And at the same time its going to be a waste if repairing is not success. will have to take a gamble here. Could you pls give me the details ahere i can get this repaired as well. Pls help!!!!!!
  8. Did not get the PM????
  9. Thanks for that!!!
  10. Thanks alot!!! Mine is a normal 1600cc.
  11. do you have any idea how much will it be????
  12. well i know its too late , but i would like to know what happened to your car????
  13. Could you pls give me the contact of your mechanic????
  14. ajwad
    Auto Gear
    Do you know a place where i coul get a a gear box??? how much will it cost???
  15. ajwad
    Auto Gear
    Could you pls give me the contact cause i am facing the problem once again. By the way exactly what did you do????
  16. ajwad
    Auto Gear
    well my car took atleast 6 seconds to move forward in D. but after using wynns i t is much more less than 3 seconds on the clock. i suggest you try it cause nothing to loose. also BG has a brand which is a little expensive. i assume its better. it is available at Laugfs. i think you should try that. let me know if there is any difference.
  17. ajwad
    Auto Gear
    The oil is red. But i think i found the solution for this without removing the gear box or replacing one. According to a mechanic i know, he advised me to put the auto transmission treatment of wynns product and i did and the car is normal now. I think it works. and it did!!!
  18. ajwad
    Auto Gear
    well! i have done about 15000km after changing the oil at Mazna.
  19. ajwad
    Auto Gear
    Hi Every one!! My Mazda is a 6BJ 1600cc year 2000 Auto gear model. 1.My problem is that, in the morning when i shift the gear to "D" the car doesn't move forward for about 20 seconds. when i accelerate the engine revs but the car doesn't move forward according to the acceleration. 2.The other issue is that when i am holding the brake on "D" at traffic perhaps, the car vibrates allot. In fact i have changed all 4 engine mounts also. Could some sincerely help me out here.
  20. ajwad
    Auto Choke
    Well guys today my car is perfectly OK. and its as normal.may be the carbon which was stuck in one of the sensors (Idle control) has gone away.
  21. ajwad
    Auto Choke
    Well it cost me 1500/= odd. Any way i started the car in the morning and it auto choked or raved to 2000rpm and dropped to 1000rpm as usual. But after that it vibrated a little and dropped to zero and the engine stopped. Is there a throttle sensor or a idle control sensor???? may be when i sprayed the cleaner into the throttle body, it would have got blocked with the carbon which is removed??? On the normal run the car is perfectly OK. Its only during the start this happens.
  22. ajwad
    Auto Choke
    Hi guys, I am facing a problem. i am using a Mazda 323 2000 1.6v auto. I cleaned the air flow sensor and the throttle body by only removing the hose. i used simoniz carb cleaner for this. after i started the car i notice that the auto choke is not happening and the rpm drops to zero and the engine vibrates and stops. but on the run there is no problem. what do you think has happened. pls help
  23. ajwad
    K&n Panel Air Filter
    guys any idea about it?????
  24. ajwad
    Yes please do. I checked with Mazn.. Motors Lali... about the K&N and he said that it can effect the piston rings after some time.even the panel type one. because it does not filter properly.
