Everything posted by Hungry_Minder
RPM goes down after long runs
Hi guys, My CK2 (EFI,1998, 190k odo, tiptronic, gear oil level seems to be fine) has a strange issue for last 2/3 weeks.According to given rpm of ck2 is about 700 (has mentioned that under the hood) and it perfectly running with and without ac. I have noticed that after running it for few kms rpm goes down to 600 and seems like engine going to die and vibrating.I have done a tuneup but no luck.After a tune up it was ok for about 2 weeks and now I have this issue again. this is happenning mostly when I put the gear to D (idling) or R.Parking and N runs smoothly. seems me when engine is heating it cannot keep the rpm and acting weired.Sometime it automatically comes to correct rpm and stop vibration. Any ideas and any recommended place get fixed this issue? Thanks
Car Shakes At Very Low Speed
Sorry for not answering but after I got it fixed by exchanging shocks (What they told it was a faulty shock)
I dont really remeber as I had some worn tires before few months ago.So I couldnt noticed that correctly.
A wobble sensation.All 4 tires with Nitrogen (30)
Hi, My Lancer CK2 has a problem that at very low speed (10-30) I can feel that left side front tire shaking.Not the right side one.I have all 4 new tires and brand new front shocks as well. When I speed the car I cannot feel this shaking.When I drive in a rough road I can feel that left side is not smooth and right side is very smooth. I have done a Wheel alignment also.But I am not sure alignment done correctly. Any ideas? Thanks
Vehicle For Permit
I phoned them and they told me this "We are not buying permits but what you can do is sell your permit and go for a Hybrid vehicle" isnt this funny? becuase they advertised something else.But guys can we actualy tranfer a permit and get a car from sale. Do you know any place.I am not having a permit but I just curious to know
- Vehicle For Permit
Vehicle For Permit
Hi, I saw and advertisment on news papaer last week. "Transfer your permit to us a get a Hybrid verhicle" Anyone having an idea baout this.Should we transfer permit for them and get a vehicle from car sale for wihtout paying a dim or what? Also I wold like to know if I have a permit how do I obtain a vehicle (procedure) Can we buy a recondition one or should it be a brand new Thanks
Tappet Noise When Cold Startings.
So yours must be the DOHC 4G15 with the hydraulic tappets then? (Do the plugs go in the middle between the 2 camshafts?). - Yes Sure I will change the oil.I have changed the oil 2 months ago.I will soon change the oil and see before do anything else Thanks
If the tappet noise comes in the morning and goes away after a few minutes, I would not worry about it. It's normal for these engines. - Noise is coming when engine is cold (yes in the morning) and sometime when it get heated i cannot hear the noise.Sometime i can hear small tick tick noise I might need to try W50 semi synthetic oil and I saw lot about this Forte engine treatment product.Can I buy it in Sri Lanka? what happened to your friends car after use this? I would like to know I have a 4G15 engine.I checked the sticker under the bonnet May be better to try engine treatment and semi synthetic oil before replace the tappets? I sent a message to Komisiripala.Thanks
Hi Don, You are correct about above facts 1.This can be but I have not checked this 2.my mechinic checked and told me its fine 3.there were some blocked oil lines and as I mentioned once they cleaned I couldnt hear the tappet noise (for about 1 month).How to clean up the engine? Flush? 4.I really dont know which kind of oils they used (previous owner) but I am using Havoline 15W-40 My biggest problem is I dont really have a good mechanic to get done these things.I need a mechanic who knows these things well.You guys know anyone pls PM me Thanks
Yes as far as I know my one has hydrolic tappets.Then Rumesh which kind of tappets it has.Better to know before the adjustment I will do a lifter adjustment and let you know.
Hi Kavvz, you are 100% correct in here.I have the same problem.But its really annonying sometimes I just talked to a person in Mitsubishi workshop and he told me its worth to adjust the tappet and see.What do you think about this? My one has hydrolic lifters
Hi Kavvz, Thanks for the answer.I remeber my mechinic told me he removed dirty things (like mud) from oil lines. So then there are still more dirty oil deposits inside the engine? what is the best way to clean them?
Thanks guys for the answers I have used this one already Havoline 15W-40 Seems then not something with the engine oil? my question is why this was gone after cleaned oil lines? tappet,rocker assembly replacement is this a expensive replacement? can only replace by mitsubishi workshop or?
Hi, I am using normal Havline oil.What kind of thick oils you are recommend?
Hi Guys, I think I need to update something here.I have a same problem with my Ck2 for about more than 1 year now.About 2 months ago my mechanic found out some blocked oil lines he cleaned them.Suprise all these tappet noise went away.But I can hear the same tappet noise again. I am not really sure about my Engine it might be 4G15.My engine has done 178k. 1. You haven't changed oil in a while - I am changine engine oil regulary.I am using Havoline oil.Before my mechanic clean oil lines I did a full service.After I changed the oil for 2 days I couldnt hear this tappet noise and it came again after 2/3 days.Any ideas? 2. You have sludge in your engine or your oil lines are blocked - Yes my oil lines were blocked and cleaned as I mentioend above.Have no idea about sludge in the engine.But I dont want to do a Engine flush. 3. Your oil pump is faulty - My mechanic told me oil pump pressure is fine.Then he cleaned the oil lines 4. You tappets or the chambers are worn - Can this be the last reason? or should I try out anything else. Your most valuable ideas are welcome Thanks guys.
D*MO Batta Like Sound Form Ck2
Sorry for late reply But I got it fixed the issue.It was something with oil line.One of the oil line was blocked and once it cleaned everything was ok Hope this might help for someone else as well Thanks guys
Sorry guys couldn't visit to the site and just saw the replies. Replacing a gasket is an expensive repair?
Hi, My 1996 old CK2 having a strange sound like D*MO batta engine sound when I start my car in the morning (or cold start) it will keep the sound for few minutes or about 1 km then will come to normal. What can be the reason for this? Thanks
Mitsubishi Leaking Water Into Passenger Side Floor Problem
Yes Guys I will definitely post the result there Thanks
Hi, My CK2 leaking water into passenger side floor when it rains and when I wash the car. How come this happen and which parts should I check and how to fix it. Thanks
Engine Misfire
Yes MV-5 thanks for the guidence
Engine Misfire
Guys I know you are experts in this field
Engine Misfire
Hi Guys, Problem solved I have replaced the plug wire set according to my mechanic's advice. Thanks all for your valuable ideas.
