dayanpad
Everything posted by dayanpad
Does it support following features Features of the OBD2 Software EOBD-Facile Trial version (free) Basic Edition (paying) Plus Edition (paying) Compatibility Diesel, gasoline, GPL and Hybrid engine Connecting to ELM327 interfaces (USB, Bluetooth and WiFi) Connecting to Engine computer (ECM), Diesel (2004), Gasoline(2001)) Connecting to Transmission computer (TCM) Connecting to GPL (since 2007) Fault codes diagnostic Reading of OBD2 fault codes (Mode 3) Reading of unconfirmed OBD fault codes (Mode 7) Decoding of OBD fault codes into text (English) More than 11 000 definitions (P0xxx, P1xxx, B0xxx, C0xxx and U0xxx) Clearing of OBD fault codes and malfunction indicator light (Mode 4) Instantaneous data reading (Mode 2) Reading of permanent OBD fault codes (Mode 10) Saving and reading of OBD fault codes Printing of customised reports Recording of customised reports Check the consistency of vehicle sensor's values Monitoring Reading of sensors (Mode 1) Continuous recording to sensor values (in a .csv file) for export in a spreadsheet Test of oxygen's sensors (Mode 5) Test of the systems (EGR, Catalyst) (Mode 6) Graphs Continuous reading of sensor values (Mode 1) In the form of a graph (1 curve) (4 curves) (6 curves) Review recordings in graph form Smart recording triggers Performance measurement (0-100 km/h) Calculation/conversion on registered sensors Extra Location of OBD2 socket in vehicles Virtual dashboard Terminal for advanced commands CAN bus spy Vehicle info (Mode 9) Commercial use VIN decoder Standards EOBD (Europe), OBD2 (USA), JOBD (Japan) ISO 15765-4 (CAN 11it/29bit 250/500 kb) ISO 14230-4 (KWP2000 slow et fast init) ISO 9141-2 J1850 VPW J1850 PWM
Hardware is cheap but software is expensive . They have there software versions with limitation . Can we able to use other software as well with this hardware https://www.outilsobdfacile.com/software-eobd-facile-elm327.php
This is 8USD
Dear All Grate thanks for the suggestion and advice as well as experience that you have share with me I am looking for to buy item that have in the following link but still supplier no idea about that support to Toyota Vitz / Yaris https://www.boutiqueobdfacile.com/obd2-scanner-pack-a63.html Please advice if you have about it
Dear All Have a nice day I need to buy a ODB scanner for my Toyota Vitz SCP90 YOM2009 I supposed to buy it from Alibaba Please advice recommended device and free software Generally what are the limitations ODB have that we can buy from Alibaba at cheap price around 10-15USD It could be grate if you can provide alibaba link too that you already used Please advice
This issue is solved Issue was operational problem
Hi team My car is Toyota Vitz 2009 SCP90 It has two motor for front and rear windshield washer Rear motor is working but front motor dose not rotate , Then I check with multi meter and found that the voltage does not come to the front motor connector So I checked all the fuse and not found any burned fuse It could be grate any one help to find the fault Please see the attached image
I believe that my method is not scientific way to check the engine condition , However most general people used to check it like that , I used EE90 Toyota Corolla ( E9 Series ). I used it over 9 years , I checked this method and I have never seen that any single oil dot come out from the dipstick hole, even at 2500RPM ( I am pretty sure )( This is my personal experience) To come out oil from the dipstick hole , there must be a vacuum pressure inside the sump , As per the piston working method , it can't be built any vacuum pressure for sump. If there any vacuum pressure inside the sump , there must be compressor leakage to the sump , Hence oil can be spreed from the dipstick hole ( I believe this is the way average people is thinking ) Anyway dear Kadsa09 your advice is very helpful me Thanks again and again
We used to this method to check the engine condition What do you men , Is there any issue remove it while engine is running Please advice the resewn to oil is spraying when oil dipstick is removed Please advice
Dear All , Have a nice day One of my friend have a Vitz 1300cc car Automatic Mileage is 140,000 Model 2008 When car keep 5 minutes at start the water come out from the silencer The emission testing report says Estimated test fuel cost Rs /Letter is 0.34 at Idle and 0.29 at 2500 RPM Car is very good pickup condition But When oil limit indicator stick is removed the oil bubbles come out So is this some issue with engine If it is issue So what kind of solution to be done to recover Still he doesn't know that the oil is burning since he brought it last week Please see the attached emission testing report Please advice Please advice
Is there ware to light up the dash board light using this three wires in above image , Then I can confirm issue with bulb or sensor Please advice Thanks in advanced
I just open the back seat and found the sensor unit It has only just three wire See the image attached In between two wires should be GND and 12v other wire should be floater output. Hence I believe that sensor unit is working Please advice The following image is not actual image of my car but but it should be same as my one . So my question is what is the operation of pointed out item by the red cycle . Can I able measure some value using digital multi meter.
Convert Your Classic to Electric Power Assist Steering
dayanpad replied to dayanpad's topic in General Automotive
Yes you are correct If we have a video exactly swap the E90 car then well help full Unfortunately I did not find it I believe that alto 800 car electric power unit may be help Advice is needed -
Hi All I have Toyota Corolla EE90 Car Production year is 1989 Very recently Fuel emergency indicator does not light up even Fuel limit go down but Fuel Needle is working properly Please advice the reason to fuel weaning lamp does not light up Is there any relation ship with Fuel gauge unit which is fixed on Fuel tank with Fuel end lamp Please advice Thanks in advanced
It is orsum , Some hard modification to be done . Electrical part is much easy . Any way thanks for the help -
dayanpad posted a topic in General Automotive
Hi I have Toyota Corolla AEE90 which do not have any Power Steering Any One who have experience to convert it to Electric Power Assist Steering I think it is more easy than hydraulic power converter Please advice Thanks In advanced -
Dear ajm and Davy Really thanks for your initial encouragement to start works on that Am going to use following sensors so please let me know if you have experience with them using emission testing Is any one should know the current ppm ( parts per million ) amount of in atmosphere related to output of bellow sensors Thanks in advance
Hi All Have a nice day I am planing to design a petrel car Emissions Testing device using Arduino which measure the output of silencer Please advice what kind of air type and what percentage should be measured by the sensors Your ideas in this regard is highly appreciated Thanks in advance
Dear Rumesh Grata thanks for the reply and advice Yes Alternator is Original and no nay modification done No any single vibration with engine and it is running very smoothly but there is a tiny vibration right side of the dish board All Features On ( AC Head Light Radio ) at Ideal Speed 12.2V ( In hear ideal speed mean... accelerator isn't pressed ) More advice
I replaced new battery. The problem is solved New Reading is All Features On ( AC Head Light Radio ) at Ideal Speed 12.2V All Features On ( AC Head Light Radio ) at RPM 2000 ( Approximately ) 14.4V A Radio on Head Light on - Engine off 11.8v All off 12.1 - 12.2 v Please advice on above reading correct or any repair to be done Thanks in advance
My OLD car is Corolla EE90 ( Millage meter 78,000 ) I when to the ordinary electrical shop and hand over the battery for inspection. The shop owner given a extra battery to me and now my car is working in order What should be the nest phase
Yes...... all are happening that you have highlighted my battery is now more than 2.2 years old I think alternator is working and it is charging the battery My battery is maintenance free one ...it indicator is showing always green Last night I traveled more than 50Km and when I back home I tried self start but it does not Hoe can i checked my battery performance Please advice Thanks in advnace
Thanks for your suggestion Currently I am using it... so I am expecting to replace original type thanks
Dear All, When I released the accelerator of my my car the radio get off and when signals is turn ON them it on and off speed also go high Please advice
I visited several location from Kandy to Gampaha but they do not have this type ( Used sellers )
