Everything posted by dayanpad
Battery Terminal For Sale
Does any one should know the place Sri Lanka to buy Battery terminal for my car in the attached image Please see the link bellow http://www.amazon.com/Genuine-Toyota-90982-06022-Terminal-Assembly/dp/B00P2RZ8TE/ref=pd_bxgy_263_img_2?ie=UTF8&refRID=1FETT0FQM2V7AV2JWKVZ Thanks in advance
Electronic Ignition Conversion
Hi, Thanks for the reply and advice Do you know about trigger ring which comes with the kit? It's operation and theory? Since ordinary ignition coli consume high current, does this unit can consume high power? thanks in advance
Dear All I have an idea to convert electronics ignition conversion of my old Toyota EE90 car it would be much appreciated if you can share your experience with me In This case we have to installed magnetic bush to the distributor shaft... as shown in the following link I guest this bush has fixed four magnetic pieces at every 90 degree...No idea where can we buy this kind of bush locally http://www.hot-spark.com/3BOS4U1.jpg please advice Thanks in advance
Toyota Ee90 Distributor Platinum Point Timing Get Change
Dear All, Thanks all for the reply Please give me a little time to upload the clear picture of the distributer Thanks once again
Dear Rumesh88, Thanks for the reply Yes I mean 1mm mechanical play of the Distributor shaft As per your advice I went to buy a used Distributes and I inspected all distributed well, all shaft of them have big play. Finally i come back without buying any distributor. Today my holiday, so I started the car and felt the same problem, then I gently inspect the distributor and I removed cap of distributor. I sow corrosion on the distributor shaft. why it get corrosion???. The mechanic always used a sand paper to clean the shaft. it is ok but shaft get tiny scratch from the sand of the paper. so what I thought is. First I cleaned the corrosion using corrosion oil and used bra so to polish the shaft (spend 45 Minutes ). then I on the ignition. Car is getting start at once with smooth ruining. Can any one help me what will be my nest steps Thanks in Advance
Dear Don, Thanks for reply I also doubt with mileage meter, but base on car condition, Let's we assume this car is low mileage . Therefore there is a no point to replace used item, used part may have same issue, else we have to repair the existing unit. Please advice Thanks in advance
Dear All I have a Toyota EE90 (Carburetor Model) Low usage. Every month I visite to the garage and adjust the platinum point Timing, then car is running smoothly. After few days car gets stop while running and can not drive past , get missed and some problems while driving. as per technician, he suggested to change the distribute. I also examined that the shaft in the distributer get loose Please some one can give me a solution without relapsing entire Distributer assembly or alternative solution is highly appreciated Replaced items Platinum Point and Capasitor Every one won't belive, this car total mileage meter is 74KM Thanks in advance
