DevakaC
Everything posted by DevakaC
  1. DevakaC
    Importing Car
    Well, what are the chances someone is going to bring down a vehicle that has never seen the shores of Sri Lanka? Yeh unless your going to bring down a Gallardo or a Vette. The chances the customs going to know the CIF value for a vehicle is 9.9 out of 10. The premise behind this requirement is if they didn't, what exactly could happen is our dear importers significantly undervaluing their invoices and resulting in a loss of revenue to the Government. In the case there are no distributors/agents/dealers in Sri-lanka for a particular model they will most likely require documentation extending verification of the Cost of the vehicle Brand new. Calculating Insurance and Freight is a cake walk after wards. Doubt they will ever consider the invoice presented by the importer, unless its higher than the CIF value they have listed. They have their own valuation procedures, the chances they going to rely on your invoice is low. Im sure out of the tens of thousands of "Personal Importers" that have popped up like wild flowers in the market would be better capable of describing this procedure of valuation. On a side note I put this sudden boom of vehicle imports as a sign of a bubble. A bubble that is prone to burst like the tech bubble and the mortgage bubble. People extending purchases beyond their capabilities with credit lines always have the risk of default. When this happens in the thousands, CABOOM! So chose your purchases wisely, drive what you can afford. Peace out!
  2. Hey Mani can you please check your PS3 and let me know if the power source compatible is 110-240? or just 110 alone? Im wondering if I get one if it will be compatible both here and in SL.
  3. DevakaC
    Importing Car
    I can answer the first part of your question. What they mean by Agent furnished value is the CIF value agents have listed for that particular vehicle. For example, lets say T#yota L@nka say a 2009 Prado costs CIF US$40,000 and your invoice says US$30,000. And of course people undervalue their invoices with hopes of lesser taxes. They almost always take the agent value and on top of that calculate the taxes. Thats what they mean by higher of agent value or invoiced value. Now if your Prado was manufactured in 2007, customs will have the value of a Prado in CIF for a 2007 obtained from Toyota Lanka and use the depreciation table on that value. And after taking the depreciation in to account they will calculate the import taxes top of it. Hope it helps somewhat.
  4. SpeedyAss, As peri mentioned it depends on if you get the 50/50 pre-diluted coolant or the coolant by its self. If you get the second kind it should be mixed with a ratio of 1:1. 1 litre of coolant with 1 litre water. What i meant to emphasize earlier was not to use water by it self. If you flush the radiator, topping it with the non pre-diluted stuff could be cheaper. If your just topping it off, always try to use the pre-diluted stuff. Also if you live in a place where water seem to be salty I would settle with the pre-diluted stuff just to be safe against any oxidation.
  5. Are Designated Drivers that hard to find about these days?
  6. So Super diesel goes in the County and 95 octane in the Z? Shah! Anywayz 10-11 Mils for a Sorento is DEEEP! Doesn't the Diesel Sportage 2010 range in 7's?
  7. Well if that's so you should have inquired from a reliable regulatory source if it can be done before swapping the engines. People usually don't convert diesel to petrol or swap bodies without knowing the required paperwork to be done. Now your not only racking up more expenses but wrecking the car. Unless you bought an already converted one and nose dived to this problem. If non-English numbers were allowed to convert freely it could lead to a worse virus than the body-permit disease that infected the market. I wonder what people behind you in a shed think when they see a 300- car pumping diesel. Incase you don't get to convert it to diesel and you sold or don't have the original engine which you had in that Opel, it would be a tough ask to find another gasoline Opel engine. Good luck on your en devour!
  8. Is this somewhat similar to Super Diesel? Diesel is still cheaper at Ceypetco isn't it? I cant figure out how this could give you the so called extra mile unless it has some additives mixed with it.
  9. Next time try and use the search option in the forum to retrieve any older posts that could relate to your issue. Anyway I can take the trouble to point out a few things since I have done this quite a few times on my own cars. Its an easy do it yourself job. If your considered about rust clogging your cooling system, then a flush should do it unless your radiator is going to need more attention than that. First you need to find a solvent that helps all the rust and other things inside come out. I usually use Prestone Super Radiotor Flush with water and run the engine for 10 mins with heater on high. Then remove the drain plug let that ish out and fill it with Coolant and ONLY coolant. Keep that as a rule of thumb! And dispose any used coolant with responsibility.
  10. Doubt you can get a Nissan Patrol Y60 for that amount of money. Unless your talking about the older model. Are you looking for a second vehicle or as a replacement to the FB15? No idea about the Panther, all i know is it has a 2.5 litre diesel (turbo?) Have a feeling it houses the same isuzu cab engine. Cant be a bad vehicle in my opinion. Market hovers around 2 million.
  11. This guy is on a mission! Do you have a personally imported Allion, Axio or Belta with Push start gathering dust in your garage, garden or back yard?
  12. Happy Birthday Peri! Experiencing ED yet?
  13. I dont know if I can agree of your claim of a Pajero being so faulty and extremely unreliable. Almost anything can be unreliable if it is not given proper care, which seems to be in your case. 1995 Pajero with 230,000 on the clock no issues what so ever other than one of the rear windows not working. It had not let us down. A common issue with these models is sunroof corrosion. Most people dont ever open their sunroofs atleast once in a while and eventually debry settling on the drain pipes, corrosion sets in. These drain pipes need to be clean and clear. Can eventually lead to leaks, and might need a reconditioned one which is abit costly in extreme cases. Also since your on the look these days, dont be dumm enough to put your foot down on the peddle and be surprised of the black smoke. Diesels tend to that and its worse with these said models. It is NOT a sign of undercompression. A 1993 being almost 17 years old now, im sure its over 250,000 on the clock and an overhaul might be on the corner depending on the state. Look for possible corrosion on the roof and rear door near the spare wheel. Some also tend to have issues with the diesel pump. Also look for uneven patterns on the tires, could be a sign of a packing up suspension system. What is the market price like for a 1993 these days?
  14. Kinda OT but does anybody know if the PS3 can be modded? And price to Mod a 360 these days? Those graphics on GT5 is just pure madness.
  15. Those wheels look bigger than 10 inch to me. More like 15.
  16. Ow Nooo!!! There goes all my hope of buying an Axio G grade now I have to settle for a X grade. What detrimental effects could this have on my acceptability levels in society? dang it! And actually i too think the F-tax is a great idea. Revenue can be increased by making people get an annual inspection done for "rear" emission. But the million dollar question is what they are going to do with people who fail the test? Rigorous imprisonment for 6 months may be?
  17. And so are the classifieds.
  18. These are cheap rumors spread by people who wanted their allions, axios, beltas, deltas and what not to be pushed sold. I have heard this story ever since the tax reduction took place. Why worry when the budget is taken up in the near future.
  19. Hey CrazyCarGuy, Thats a good looking D21 you got there. Have been through a full restoration of a 50-xxxx Toyota LN85 in the past. From Exterior, Interior to Rancho Shocks and Armadillo bumpers. My father happen to import winch's so had one of those set aside too but had to leave the country for studies. So I do have my fair share of liking to the double cabs. As some of mentioned above there are many current and past owners in the forum with banks of knowledge from Toyota's to Isuzu's, Nissan's to Mitsu's and even Ford's. I would love to see a new thread come up dedicated to Double Cab owners and admirers since we are stealing a Mitsu L200 thread. As for some of the questions you have posted, if your engine is burning more fuel than usual even after an injector cleaning and the engine seems to be burning up engine oil it "could" be your engine is going through phase of under compression. That could be your answer for the low fuel figures. Right around 7-9 should be the avg. Also some engines tend to burn up some engine oil with inherited issues, like the Mitsu 4M40 and Isuzu engines. But in your case if it burns up a significant amount that "could" indicate possible under compression. Also undercompression would not necessarily refrain your engine from firing up in cold weathers. So I would say best is to get a compression check done if possible and if it is under what it should be consider an overhaul or a new engine. Personally I prefer and overhaul if the engine is still a virgin. But if it has been through one already, I would rethink and probably settle for a reconditioned engine with much dislike. More or less those recon engines turn out to be worse nightmares than what we already have. Its your call if you would like turbo unit in there or not. If speed and acceleration is what your looking for then go for one. May be the more technically wise can clarify if a Turbo Engine and it's lifespan has an inverse relationship? Cos I feel like the ones with turbo's tend to wear off faster than the ones without. I could be wrong.
  20. Hey thanks mate, but im not in SL but if I do require some help in the future i'll keep it in mind. Just a general fact, as for now in the US an Iphone 4 costs about $600-700. The worst part is you cant buy it over the counter, it requires a 2 year contract with AT&T. But there are plenty of people who sign the contract, get the phone and sell it at a slight premium. Still the phone would be locked for AT&T. What is the market price like for an Iphone 4 in SL?
  21. HAHA I wouldn't actually. What is AOD btw?
  22. After Jail-Breaking the Iphone you can download apps for free using a software called Cydia. They have pretty much anything and everything. If not you can have the pleasure of paying for your apps through App store. You get stuff free too. Ive used the 2nd gen and currently a 3rd Gen. Both were unlocked and Jailbroken. I am not a AT&T customer. If I had enough dough I would go for the fourth.
  23. Bet that function was great. Happen to have a link for that?
  24. Best is give a call and confirm. But I highly doubt it would be 2.2 million. There was one on Hit#D-online asking 4.5 million. White one..
  25. Prices are Increasing at a decreasing rate. No supply demand theory can explain the trend at the moment.
