Soh
Everything posted by Soh
  1. Thanks John, Yes, Let's see the response of the dealer. But, till that, can someone say that will there be an issue on ECM or ICM? Or, should I reprogram the Key Transponder? Is there a way to do that? I did the instructions given here, but didn't work. https://itstillruns.com/reprogram-transponder-key-7602240.html Any other way for it? Thanks.
  2. Thanks. If the connections having fault, how it will be OK after few time? Anyhow, I will bring it to the Suzuki Dealer. Thanks.
  3. Thanks for the instruction. But, how? What do I looking for? Can I do it by myself? Or should I have to go to a mechanic?
  4. Time changes lot. I measured the time with a stopwatch. Once it gave 1 min and 6 secs, and some times more than that and less than that. There is no rounded time like 1 min, 40 sec, 30 sec, etc. Thanks.
  5. Dear iRage, Yes, Lock & Unlock functions of the Key are working properly. Recently, the Fuel Pump and the Fuel Pump Relay were replaced. I'm not sure whether this issue came before or after that replacement. Thanks.
  6. Dear John, Thanks for the response. This is a Key in Model. It's having 02 Lock/Unlock Buttons, need to insert the metal key to start. Unfortunately, it's not a AWD. 😪 Thanks.
  7. Dear All, I'm having Suzuki SX4 2011 Japanese Model Sportsback (Not Sedan) Car. There is an issue in this car with the Immobilizer. When the key is turn to the ON position, the Immobilizer Bulb doesn't light up immediately. Accordingly, when the key is further turned for starting, the engine doesn't start. But after keeping the key in ON position for about 5 minutes, then light comes up. Then the engine can be started. If I start the engine and stop, and if I again turn the key to ON position, then the bulb comes up, and can be started. If the car is stopped for some time, then same issue comes up. (Waiting time for illuminating the immobilizer bulb is varied.) I replaced the battery of the key, but the issue is still there. Can someone help me in this regard? Thanks.
