2
Yes...L048 was the model designation for the LWB 2.3TD. I think 46,47,48,141,146 were long wheel base versions.
Typically there is a G at the end if it is a SUV variant; if not it was usually a van which was a (V)/special vehicle variant.
Now...the following is just me spilling out what I remember. The combinations were endless and with so many markets there were quite a few codes....but generally in the Japanese market and a few other general export markets:
The segment after the "-" indicated the body and spec variations....
If the first letter was a W it meant it was a Super Wagon, V at the first position signified a Van (...in the japanese market which was referred to as a wagon in export markets...not to be confused with the V at the end of LxxxV), the G at the second or after position was designated for Wide body/fender. A "R" (not at the end) signified 4A/T, F a 4M/T and N a 5 M/T. A standard V at the beginning implied a Metal top which is either a flat roof in case of a 3 door/SWB or a high roof in a LWB. A M indicated a mid-roof (which you are referring to as flat roof). T at some position for Turbo. L or R at the end signified a LHD or a RHD. In the Japanese market they had a J, X or a D to indicate a grade. For some models J referred to GL and in some JX and the X indicated a XL and D indicated DX.
I have no idea what your VGJ code is....the Japanese market unit did not have a VGJ code. If one was to use the Japanese coding scheme it would mean your vehicle was N/A, was in a market that had only one type of transmission, was a Wagon (or in Japan a Van), came in a wide body configuration (in some markets this also meant that it had the wide track but not necessarily the wide body) and was a GL grade. Since the M is not there it might suggest it is not a mid-roof.
Again..the permutations were endless depending on the market....so yeah....
Budding and swapping bodies is illegal (in all parts of the world) for safety and security reasons. If a body has been swapped LEGALLY, there should be letters from the RMV authorizing it and the issuance of a body permit for importing the body (or something of the sort; not entirely sure of all the documents). Basically,the only thing you can swap without prior approval are the body panels (inner frame/chassis needs to be untouched). Even then the body panels have to be a one to one replacement and not change the original design of the vehicle. In SL, people get away without any of these formalities because our guys are too lazy to check the legality of all these and even if they did check they turn a blind eye if "gratitude" is shown.
