The engine overhaul was done in Jun or July 2023. There is not a single problem with the transmission. It shifts smoothly. I drive in the worst city in the world called Dhaka.
It was not run on LPG but rather CNG which was very harmful for the engine. I did not get all these checks during the overhaul but I am ready to do it now. No burning oil smell and the smoke is not that visible.
The ECU has changed. The original one I looked up online and found a part code 89661-1A440 where my mechanic installed 5aFe ecu but the part code is different and I don't know which car it is from. The part code of the ECU in my car right now is 89661-12710.
I could not find the original fuel injectors so I put the one compatible. It is maybe a Chinese one.
I guess the right wheel size of my car is 165 80 R13. Also, I want to know what SR means. Like 165 SR 13.
So I came up with an initial fix that I have to change the ECU, the injectors to the original ones, and the wheels to the original size. Maybe that will fix the fuel consumption issue. What do you think?
