HardHat
Everything posted by HardHat
  1. as for this car being an AUTO, keep the gear lever at "P" BTW TharakaWi, you can very much 'down shift' in a vehicle with AUTO transmission as well. However, because you haven't got clutch control, you need to find out by trial and error at which speeds it is safe to down shift from D to 4 - 3 - 2 - L / D - 3 - 2 - L or D - 2 - L (depending on what configuration you've got with your car), without over-revving the engine. If you are upto it, a much more scientific way of finding out the 'shift-points' is to start on a straight road from a stand-still and keep the accelerator floored (well almost - say give the hardest acceleration you would give without blowing up the engine) and to note the speeds at which the auotbox shifts gears I think the Starlet is a 4 Speed auto with a D - 2 - L configuration at the shifter, so if you are down shifting from D to 2 then you are coming down two gears at one go, so do it with good judgement of your speed as for driving downhill - definitely be at a lower gear and foot off the breaks - not at D and foot continously on the breaks
  2. TharakaWi any modern vehicle has got at least two independant circuits (break oil lines) serving front pair and rear pair of wheels seperately so if you totally lost breaks the problem could be at the break pump / master cylinder / break oil reservoir, and not at any of the wheels if air is trapped in one of the hydraulic lines you should still get breaks at at least two wheels, be it front or rear depending on which circuit has trapped air. furthermore, if air is trapped then it doesn't come back to normal by it's own - you definitely need to bleed the air out. So I think we can rule out trapped air if the pedal felt light and went all the way down with normal or lesser effort that normal, then we can rule out any problem with the break booster or the vaccum as well I assume your Starlet has got disks at front and drums at rear. So chances of a break bind which could heat up the oil throughout the entire break circuit are remote. Furthermore if break oil was heated up then it takes a bit of time to cool down and breaks wouldn't have come back to normal quite quick as you mentioned I would first check the break oil reservoir. If any piece of dirt or a foreign object is trapped in the reservoir, it could have temporarily jammed the oil supply from the reservoir to the master pump if the resevoir is clean, then I would get the ABS checked (if the car is equipped with ABS that is). You are not supposed to loose all breaks at a failure of ABS but that's wherer the next suspicion is on, based on your description of what happened. It could be a simple problem like the ABS temporarily loosing power supply due to a loose connection, or something far serious like the ABS pump jamming. However, if this was the problem, you should get the ABS warning light flashing or lit up in your dash when the problem occurs next step would be to get the master pump checked Having said all the above, as this is a life-threatning problem, get the full system checked but make sure the mechanics take the above sequence or at least pay attention to the above probabilities and not simply replace brake pads and washers and charge you top $$$ while the problem may still exist
  3. if you want a realibale workhorse that would keep running as long as there is gas in the tank - then Corolla AE110 wanna feel sporty - the Familia FB15 - there are quite a lot (may be too many) of them on the streets so them no headturners anymore
  4. Guys, check this chap out. He has done a few remarkable rebuilds. His current project is a 1980 CB250N, exactly the kind I'm looking for. Tom McQuiggan Hope there are bike enthusiats in SL also with a love for classic Jap bikes and this much attention to detail and a this is an example of a 'showroom condition' CB250N 1980 Honda CB250N
  5. Prad I say we load our guns and track the animals down. If plans go well I'll be in SL end May for a short break. Care to do a headstart and let me know the progress? You've got my email ID in this thread before should we need to communicate indoors BTW, my quest for a CB250N / 250 Hawk is still on everyone
  6. Shamitz, good stuff mate this is a great lead. Will defa check this guy out next time I land in Colombo
  7. Pradfred, just find me a CBX (by that I mean a 1979 or 1980 CBX 1049cc air cooled transverse straight six with that many carbs - the naked version before the spoil-sport body kit came in), streel legal in SL and you get to take it for a spin!!
  8. awesome - however I prefer the CBX unmodified in it's original apperance see that the pic is from AU - there is a loyal fan base in AU for the CBX I was visiting Perth late 2007 and this guy pulls up alongside me in a gas station in his 1979 red CBX, in pristine original condition to the last nut and bolt. A quick admiration from me and the 'mate' offers the bike for a spin around the block . I will never forget the growl from those pipes on hard acceleration and moreover, the scare it gives when cornering. Just the slightest bit of lean and the weight of the bike pulls you onto the ground so you really need to have loads of momentum and counter balancing of your body weight to stop it from falling over.
  9. Boys, a feast for your eyes while we are on the subject. Sorry not my own - a hijacked pic from bikepics 1979 CBX 1050cc
  10. yep. Mon-Tue is fine thanks Ash
  11. sorry to drop a spanner in the works but if u think safety, you would be worried A head on collision is most likely to do very painful damage to the legs of front seat occupants These are designed to to deliver food and merchanisice, etc through narrow streets and busy market places and the like in congested cities, not really meant for highways. By all means buy one cause they give commendable value for money and very economical to run, but be careful on the road
  12. could you let me know the owner's name or direct me to the garage in Wattala? My email id is in this thread above. I'm prepared to pay insane $$$ if I can get hold of a CBX
  13. Ash, I'm out of country as well and visit home often as and when needed Any chance of seeing a pic or two of the bike via email and a bit of details like M/Y, Reg year, No. of owners and km? [[email protected]] thanks in advance.
  14. yo Ripper! glad you jumped in to this thread. Lemme clarify a little - it's not that some folks don't like two smokes, but raher getting too old for those fast crotch rockets and not so agile anymore to find that bent froward riding poistion comfortable otherwise love those TZRs, MTXs and NSRs the MVX, yep I remebrer those. A distant cousin of mine had one, decent fast bike but had engine probelms ever now and then and used to smoke like an old CTB bus any lead on a CBN?
  15. Ash, pl give me a lead to the Hawk
  16. whoa! there is a red CB1000 in SL as well? That means there are two (or perhaps more). The one I've seen was silver. Is the bike registered / street legal? Any chance they are selling? The CB750Four was a pure classic. Had a poster of the full range of Honda bikes of M/Y 1980 on my bedroom wall and the 750Four was a one featured in that, along with CB900F, 750 Bol D'or and GL1000 Goldwing The XS 250 is a two cylinder and not bad in terms of reliability. There may be bigger XS's 3 Cyl or more which may be prone to give trouble anyway, my first choice is either a CB250/400N or 250Hawk
  17. Hi Rizvi Nice to meet you, finally, looks like I'm not the only guy who has a taste for this rather strange 4x4 what model/year you've got? Rizvi I work in the Middle East and come home once every 3-4 months. Need a few parts for my Deli - the front Bull-bar, a hood light, some switchgear on the dash, etc. Do you know a used parts dealer around Colombo who has got a cut up Deli or two?
  18. Hi Shamitz TZR is a cool bike but I'm somewhat a 4 Stroke fan so most Yamaha s are not for me. Had a Yamaha SR125 abt 12 years back Hi Kotte sounds like you live abroad. Me too and visit SL once in 3-4 months. I'm pretty tired as well to see the Indian crap running around. They may be cheaper to buy initially but most wan't last more than 3 to 5 years. A good old Jap bike will run for decades if taken care of properly. One of my uncles got a 10Sri 1980 CD185, still giving that original beat not heard in CD200 or CD125 which came afterwards
  19. Thanks Supra In SL many people do not go into restoration of old cars or bikes because of the cost and difficulty involved in finding parts I guess. As such, if a machine had not been kept in good nick, it will most probably rott down to the ground. I remember in early 80's a "Sudda" had imported a Honda CBX to SL (for those who are unfamiliar with bikes, this was the only 1000cc air cooled in-line 6cyl 6carb bike ever produced in the world so far). Seen him on Kandy Rd climbing Kadugannawa once. Wonder if that bike is still alive. I also used to see a Honda CX500 (liquid cooled V-Twin) parked outside a motorcycle workshop betw Dehiwala and Mt.Lav for a long time in early 90's.
  20. hey! no off-road nutt here using a Deli?
  21. hey Pradfred, just jump in. It's better to have company in this quest Well I'm looking for four stroke and never mind being not so quick RD 350 for 25k? that's damn cheap if the bike is in running condition. A freind of mine had a Honda NS350 back in 1990s - remember those? I think Fred Spencer was riding NS500 when he took the world championship. One more bike I would be interested in is Yamaha XS 250. Another mate of mine in STF is having one for 14 years now. Olive green and in immaculate condition. Never selling though. I wouldn't trust the guys down Panchikawatte. There should be good examples of these old big bikes just sitting around peoples' backyards cause they are bit too expensive to run and maintain these days.
  22. Sheran mate, a BSA is bit too old for my current requirememnt. My dad had a C15 sometime back. Would like to own a Triupmh Bourneville someday though Ash, very much interested to hear about the Hawk. My email is [email protected] anyone know about a CB250N or a 400N for sale? Cheers
  23. looking for a big Jap bike in good condition from early 80's Honda CB250N, CB400N, 250Hawk, kawasaki Z200 or something similar - those heavy air cooled, twin piped naked bikes - is what I have in mind any leads most appeciated
  24. Are there any Mitsu L400 (Delica) SpaceGear owners in this forum? Bought one recently and need to network with some fellow owners for info / tips, etc. BTW, mine is a 1995 GX 2.5L 4D56 Turbo with an intercooler fitted locally
  25. any of you guys tried datamanuals.com?
