Everything posted by VVTi
- Breakdowns On Toyota Aqua
- Pajero-Io Left/front Abs Sensor
Airbags
I bet you re-use condoms...
How Important Is The Thermostat?
Yes, that's the one Drain the system, pour 2/3rd of the bottle in, fill up with distill water, bleed/burp the system. Fill the balance in to the coolant reservoir and gain top up to the Fill/Max level with distilled water. For your Mitsi, I would say use the Valvoline stuff that is available at Unimo. Nilanka who does work on my Subie said the Valvolone stuff is what he uses. I was too lazy to drive to Hyde Park and buy the can, hence the easy Wurth path. But so far, quite happy with the results.
adding to what Rumesh said, and ensure you fill up the coolant system with the closest type of coolant you can find locally. NOT that STR shite... either go to UniMo and buy the genuine stuff or Wurth or Valvoline at UniMo. Avoid the pre-mixed Caltex Lanka Lime crap too... One more thing Trinity, this a a bit too extreme. but I did just to be sure, wipe the inside of the tail pipe really well with a cloth and ensure thee is no soot. After a few days driving check with your finger to see the level of soot, a light coating is good news! That is more or less a physical clue that the car is not running rich anymore.
Great news!!!
Bit of an update. Since the stat and the CTS went in, my fuel figures have improved. By how much?, I hear you ask.. LOL Without the thermostat and the old CTS, I was happy with 4-5kmpl in the city, but now, I am averaging 7.5- 9kmpl... as long as I keep to low boost. Yes, it has made that much of a difference.
[Wanted] Mitsubishi Lancer Glx 2003 - 1.6 Cs3 Owner / Lover / Ex-Owner
true, but machang, any monkey whose keyboard skills are above average should know that when you search, it helps to type in Model name or manufacturer name also, right? Imagine typing 323, it could be Mazda, it could be BMW, it could Geely... come on, its common sense. We have to stop making life easy for some of these in bred retards.
The Check Engine Sign (Malfunction Indicator Lamp)
Check the plug leads, check to see if your petrol cap is closed, any loose connections/sockets... do the basic walk-around first.
- 12 replies
- check engine
- malfunction
- indicator
- light
Its been said that during roman times the display of the upturned finger is an indication that the owner of the said finger is ready for anal penetration.
Ek3 Vi Starting Issue
Sometimes some faults do not throw errors. Check the numbers during a live scan. 80K after a T belt change means its time to change, especially in SL. It could be some notches are broken in the belt and a few teeth have jumped.
CAM sensor? What is the state of the T Belt?
LOL, not at all. I am glad this discussion has got people thinking. I hope our maka baases wont start removing 'stats off Hybrids too... ha ha ha ha!
Ok, will they fix a part you bring from the outside? Actually, you can DIY...
Ideally it should start opening before water starts boiling. Opening at the point means the coolant ahs reached boiling point. Mine starts opeing at 78-80 and is fully open by 96 degrees. Put a new one in. I was thinking, if UniMo said 7k for replacing, is that with the coolant and labour also? If that is so, then it might be a good deal. Update on mine : Just collected the genuine Coolant Temp sensor. Will be putting it in tomorrow morning as to replace it is a PITA. Need to remove the alternator to reach the CTS. Not advisabe when engine is hot.
Airfix And Other Model Builders Thread
Used to buy and build Tamiya kits when o/seas. had a fairly large collection of WW2 fighters and bombers. 1:72 scale stuff like a Junkers Ju87 and 88, P57 Mustang, B17 Flying Fortress and a Spitfire and favourite a P38 Lightening whose Superchargers on the engine nacelles required me to glue the turbines one piece at a time. Largest one I had was a scale model of the Russian carrier Kuznetsov complete with her fighter complement. Took 4 days and nights without much sleep to complete Fun times. A completed Kuznetsov. The pictures do not do justice to the amount of detailing it has. http://www.shipmodels.info/mws_forum/viewtopic.php?f=46&t=34697&start=90
That's more or less the manner it works elsewhere too. ROFL on the toothbrush.. Recommended by dentists I suppose.
Funny you should mention the radiator fan operation. My stat starts to open at 78, and fully opens at 96. However, the fans come on at around 99-100 degrees. I am playing it safe and ordered Coolant Temp sensor as well. Should be getting it deleivered tomorrow. It is a 3 wire uinit where each wires is connected to the ECU, gauge and fan relay. Either of the 3 circuits failing will cause an issue. So getting that done as well.
What is your vehicle? Chek on Ebay. If you have the sample a small walk around Panchi might sort you out.
Pajero Io - Alternator Belt Cuts Off The Engine
I am thinking the crank pulley Harmonic balancer.... long time I ago I had a Ford T Bird while working in KSA. Engine was running funny and the local Mecury agent tightened the belts and the car started stalling. Took it again and they noticed the Harmonic balancer was busted and the extra tension on the pulleys distorts the pulley and causes the engine to splutter and die. Dont ask me why or how. Replacing the crank pulley sorted it all out.
I couldn't test mine this way as it was never there in the first place. LOL. Don't be surprised with UNIMO's comment, I got the same harrang from my agents. They dont even stock it saying no one buys. Can you beleive it??? And I am still waiting for Borella Motors to get beck to me with a new part... LOL. I already got it delivered from SGP and is running with it.
Without removing the stat, you can actually check. On a cold start, open the radiator cap and watch and wait. If around the normal halfway point on the gauge you see the water churning that means the thermostat opened. Depending on your vehicle, the fans should come on soon after this point. Or track the hose that comes from the thermostat housing and touch it and see if its warm. Ideall it should be cooler than the rest of the hoses if the thermostat is there. Make sure you replace the water that spilled during this test.
What I would suggest is to replace it with a brand new part. Testing as Rumesh said will confirm the the operational condition of the thermostat. YOu might as well drop in a new one while you are at it. If its 7K at the agents, it is surely much less outside. It is a DIY job anyway.
