Riz
Everything posted by Riz
  1. Thnks mates, shall chk all recommended actions, if any one cud advise me on as to why engine speed fluctuates (morning starts only) speed increases and decreases on its own and when engine reaches a normal tempreature runs fine. Followings done Throttle cleaned Plugs cleaned Little bit of sludge evidenet when tappet cover opended, cleaned and refitted Engine flushed and new oil and filter changed. Can sensors be checked at home, dont want 2 take it 2 a garage as far as i'm concerened i wud spend only $$$ for no return, my experience for this van, initially took (known garage) , fellow cleaned t plugs and wanted to replace the coil pug which costed me 6.5K , sprayed little bit of a cleaner to the throttle body(which i bought for 1.8K and ultimatley that F***** didnt use even 20% of the spray and when i went 2 buy the coil, fellow stole it and said everything was used) and charged 2K . Total labor charge including the stolen stuff Rs. 3K (approx) Later a cold start in the morning same problem speed flutuates, so i chcked on my own , the old coil was firing properly and luckly returned the coil and got the money back , did all the cleanings and the above stuffs at home. Any advise pls
  2. Hi bro this could be due to the engine speed sensors or sometimes due to air mass meter.(what make /model of mini van?) plugs getting black - probably overfuelling, also need to check the coolant temp sensor first, pls check whether the sensor connections have corrosion and bad contact. probably has oxidation from long storage. hope this helps It's a Daihatsu Hijet 650 cc
  3. 168,000 kms
  4. I have a mini van 650 cc, EFI bought recently from a vehicle yard ( repossessed vehicle) , starting t van specially in t morning bit difficult, at idle, speed tends to fluctuate (increase and decrease on its own) and when engine reaches a certain tempreature runs fine. Engine stalls occassionally when t engine is hot (middle point) and starts again when cold. Checked t followings 1) Throttle body totally cleaned with a spray 2) Plugs cleaned and refitted 3) Coils ok 4) Mixed injector cleaner with petrol and ran Followings issues noted - Plugs somewhat black - Engine oil very thick (Tappet cover was removed due to oil leakes and saw due to the thickness of the oil greasey like substances was all over , cleaned and refitted) Can anyone advise me on these pls 1 - Engine Oil will it affect the speed fluctuations 2 - Engine stalls occassionally, (couldnt figure out as to why ), sometimes when a/c is switched on and starts when cold (Can this be due to a sensor fault) Any advise pls
  5. Riz replied to Riz's topic in Mechanical problems
    Is there any place where i could chek the sensors in Colombo 06 or vicinity, since there s a garage down Saranankara Road Au** For** said they dont have the computer programme to check Daihatsu Hijet. Checked the coils ok, Cleaned t throttle body ,air cleaners , plugs were black and cleaned and refitted. 1) Can rich mixuture occur due to a senor fault, how much sensor check would cost , which sensor probably at fault 2) Any other recommendations pls
  6. Riz replied to Riz's topic in Mechanical problems
    Thnks buddy, infact i cleaned t plugs and ran and checked t plugs again were good, probably as u said i too felt the issue may be due to a rich mixure, i have been using carb cars for many years , if it was a carb issue i would have diagnosed by now, not very much familiar with EFI's, is there any way i cud clean t air flow senors (spraying cleaners) and also will sprays work.
  7. I have a Daihatsu Hijet mini van 650 cc, EFI, If any good soul could advise me on this problem. 1) After starting, at idle the engine speed raises and decreases this continues till the engine reaches a certain temprature 2) Sometimes the van doesnt accelarate after the tempreature meter reaches half and engine stalls, engine starts again when cold 3) Could here a "BUF" noise on idle and accelaration (Perhaps unburnt fuel) Took t van to a nearby garage, fellow sprayed little bit of injector clearner was quite ok, but t miss was there, after 15kms or so engine stalled again and No (2) again. Perhaps i think should buy a injector clearner and fuel clearner and clean the throttle body n c, Any adise on this pls
