jdnet
Everything posted by jdnet
  1. IIRC on my car I have to jiggle key while in the cylinder and turn the steering wheel at the direction where it got locked while turning the key. I may be run. OP the locking system is a basic way of preventing car theft. If you lock your steering wheel after you park a thief can't drive your car after hotwiring it. It's actually wierd that people would spend money on immobilizers when they could just lock the steering wheel.
  2. wow so projectors are now scoop lights. What next?
  3. Well I just bought a haier wet/dry vacuum from abans so that I can shampoo the seats too. A small hand vacuum would work fine. The one I got cost something like 13000 IIRC.
  4. He said fog light AND scoop light. Wonder what the heck a scoop light is. Gotta love Sri Lankan names for things. Among the worst: boku alloys and kaney mile.
  5. Yeah but that's a brake booster, not two doors. Size does matter.
  6. Ahh yes forgot to add that. Although I haven't been using a jack as of late. Waiting till all my tools including the jack stands and floor jack get shipped here. Although there's plenty of work you can do in the interior and engine bay without a jack.
  7. 60,000 sounds reasonable to me. Keep looking though, you may find something cheaper. If you calculate the cost of freight and taxes you will end up paying the same amount if not more. Now if you were importing small spare parts it would be a totally different story.
  8. I have never taken my cars to a place that doesn't let you in the workshop, don't think I ever will.
  9. So you want to be a mechanic eh? Here's a few pointers and stuff you would need. 1. Make sure you have a good attitude. Acting like you know everything is not helpful. Even the most experienced mechanics need advice and help sometimes. Use all the resources you have. The internet is one of the most valuable of them and the fastest. If you can't figure something out, rest assured someone on the internet already has a solution. Use sites like autolanka to find solutions to your problem. Also chances are there will be a forum specific to your model. Use it to find solutions to common problems your car will face. 2. Working on car's is a learning experience. With learning comes reading. Read up as much as you can find about your car. Find manuals or just use the internet once again. 3. Be patient. If you run into a problem while working on tghe car take a break. Chances are with a clear mind you will be able to look at it better. If you smoke go have a cigarette. If not, go have sex. What ever puts you at ease . 4. Be organized. Always keep track of your tools, parts and any bolts and screws you may have removed from the car. Having a tool or anything else lost in the engine bay and hitting a moving part will make for a bad situtation. When dealing with screws and bolts use plastic cups to hold them. If oyu are working on more than one part the use cups for each part to make sure you have the right bolts. Always tighten screws by hand before using a wrench. It will prevent stripped threads. Also if you drop something into the engine bay, your priority dshould be finding it before moving on. 5. Avoid speaking on the phone while working. Just like talking while driving using the phone while working will cause you to loose concentration and make mistakes. Trust me I speak from experience. 6.After completing a job recheck everything atleast once to make sure everything is in place and the bolts and screws are all in place and tightened. 7. Build yourself a basic tool kit. If you are on a budget get the stuff mentioned below. 8.Start small. You are not going to start learning how to work on cars by rebuilding an engine in one night. Start witgh the basic things such as spark plugs, sensors etc. 9.Have fun and relax. Don't stress youself out. While it may be impossible at times, most of the time working on cars should be a fun and rewarding thing to do. That's Just some basic pointers. If anyone has anything more to add please do. Tools Here's a list of basic things you would need to start off as a new DIY mechanic. The following tool kit is what I'm basically using at the moment until my more professional tools get shipped to me in January. This would be a perfect budget kit for anyone putting his first step into the field. It won't cover anything extensive but basic things and even some advanced work could be accomplished in with it. Now you don't have to buy all this stuff at once but it will help get things done if you don't want to drive to the store each time you do something. Socket set You can find a 1/2 inch drive basic set that comes with the most common socket types for Rs. 900. You will need to however add a 13mm socket if the set does not come with one. Also there may be sizes that are uncommon in most cars but are needed for yours. You can buy them seperatley at about Rs. 100 a socket. Ratchet Ratchets can be bought from Rs. 400 upwards. If you don't want to invest a good deal of money in your tool kit or just want something to use every once in a while then buy a chep one. Make sure the drive size matches the socket. Wrenches. Not sure about the price but you can find a basic wrench set for cheap at almost any hardware store. Also try arpico. Having the box end on one side is a plus. Ratchet extensions Ratchet extensions have a variety of uses. The most common use is for reaching the spark plugs. What you will need is a 10 inch and a 3 inch extension. The 10 inch extension I have is relatively expensive at 600 but there are cheaper ones to be had. Spark plug socket Most garages in Sri Lanka just use an ordinary deep well socket and use the plug boot to pull the socket out. I really think it's better to use a specialized spark plugs socket. There are two types. One has a magnet to pull the plug out and the other has a rubber boot in the inside. I can tell you for a fact that the rubber boot ones get pretty annoying when the boot comes off each time. I got a magnetic one that cost Rs. 450. The mostr common size you will need for a car is 16mm. Flash light. Use anything you want. A flash light comes in real handy when trying to look at certain parts in the engine bay. It would be nive to have a standard size together with a small penlight. Screw drivers Phillips, flat head. Get an assortment of sizes and leanghts of cheap screw drives. Also make your that you and a couple of stubby ones. Screw drivers (torx) You may need a screw driver handle set the comes with a torx bit set for certain applications. Rubbing compound 3m or similar. 3m costs 1400 for a big bottle but there's other brands for 400 up that work just fine. Carb cleaner Buy what ever you think is good. Rs. 400 up Penetrating oil wd40 or similar. It will help with stuck and rusted bolts. Anti-sieze While not commonly used in Sri Lanka, most garages elsewhere use anti-sieze on the threads of bol ts such as the ones holding the coil packs for spark plugs and also on the spark plug thread itself. Using anti-sieze makes sure you get that bolt out every time and prevents stripped threads. Not sure where you would find it here but you should look around at that famous tool shop. It should be relatively cheap. Wet/dry sand paper Some wet/dry sand paper would come in usefull for various things such as restoring lights, prepping for painting and even cleaning parts. Have a few sheets of various grits in your tool box. Contact cleaner You will need this to clean up various sensors and other electrical parts. Soldering Iron and solder A soldering iron would come in very useful for things such as installing a new harness for a new radio. I use a butane one but a cheap electric one would work fine.
  10. http://www.google.lk/imgres?imgurl=http://images.drillspot.com/pimages/2903/290333_300.jpg&imgrefurl=http://www.drillspot.com/products/448752/3M_39002_Abrasive_Rubbing_Compound&usg=__RvR4vpcXuUB7w39qfv2hX1PTdEw=&h=300&w=300&sz=15&hl=en&start=0&zoom=1&tbnid=iKT3Jl0bUKhzMM:&tbnh=148&tbnw=148&prev=/images%3Fq%3D3m%2Brubbing%2Bcompound%26um%3D1%26hl%3Den%26safe%3Doff%26sa%3DN%26rlz%3D1T4MOOI_enLK386LK386%26biw%3D1020%26bih%3D561%26tbs%3Disch:1&um=1&itbs=1&iact=hc&vpx=132&vpy=67&dur=31&hovh=225&hovw=225&tx=146&ty=91&oei=OKj8TJeZEIvRrQeF4tjSCA&page=1&ndsp=15&ved=1t:429,r:0,s:0 It's the regular rubbing compound. Not the heavy duty stuff.
  11. 1. Don't think there are any aftermarket solutions for it available in Sri Lanka. What you could do install the radio in your glove box (cubby hole). Most radios now come with a remote that you can use to control it without touching the radio. You will have to fabricate a braket to install it but it's pretty easy and will keep your dashboard in the stock condition. 2. Did you check the fuse for the lighter? If that still doesn't help you can have a new one installed. It won't cost a lot. 3. Are you talking about after market fog lights? If so it's a relatively simple install and any good mechanic could install it for you. As for good mechanics in your area I don't really know. I'm sure someone else will chime in.
  12. I think the statement that toyota has Never had to replace a battery pack if quite untrue. Although rare there have been cases in which they had to replace it. On the point of the cost of a battery the 2010 and later batteries cost 2300 not including shipping. Getting a 100 pound battery here is going to cost atleast another acouple of thousand. On top of that there will be taxes as replacement batteries are not tax exempt.
  13. I think the biggest problem would be to have to have a mechanic willing to look at an actual repair guide, go abroad to get certified and invest thousands of dollars on scaners/programmers. I think there are only a few places here besides toyota that would have the capability of investing so much to carry out the maintainence of hybrids. The result would be really expensive trips to the garage as they would need to cover the money invested in a technology that's new to the country. Now if people were buying hybrids brand new this would be less of an issue for a while atleast,but if people were going out and buying hybrids that have been used for three years then issues and lines at the few places that fix them would start forming pretty fast. Oh and the end result of this would be that I would throw my wrench andstop fxingmy car myself because I can't afford to invest so much in tools so I will just ride my mountain bike to work.
  14. Well the tribute does has an efi engine as far as I know. Spraying the carb cleaner does help clear out deposits through out the air intake piping all the way down. As for if carb cleaner is the best product for cleaning IAC valves, as far as I know it is. It helps remove the carbon deposits effectively without the need to agitate them. Although if the deposits are tought you may havetouse a cotton bud. To find the IAC valve, simply locate your trottle housing. It will be bolted onto it and have a wiring harness connected to it. As for the question on how often the IAC valve should be cleaned, I can't exactly say but looking at how badly mine was and taking into account the miles I have I would say about every 45,000. Just a rough estimate. Last but not least.....as for your wife attempting to murder you if you worked on the engine, I will not be held liable for deaths caused by spouses. Please direct questions such as that to my attorney. .
  15. Well that's something I would have to test and let you know the results. The reason rubbing compound works on minor scratches on paint it because they are on the clear coat and the rubbing compound lightly sands the clear coat to the depth of the scratch. In theory it should be after to soften light scratches on the interior provided that the scratch is really shallow. I will try it out and let you know.
  16. I'm pretty sure all the shops in panchigawatte have stocked spare parts for the alphard just because you are going to be the only owner in Sri Lanka.
  17. Lol I'm just enjoying my last days of freedom until my wife moves over here. FYI stuff like removing IAC valves and cleaning is much easier than it looks. The whole process of removing and cleaning the IAC valve would have taken me only 10-15 mins has I not been taking pictures. Just take the leap and get some tools. Lol. It's an addiction.
  18. Did you check the spare wheel well? It may be on top of or under the spare wheel.
  19. Forgot to note that You should allow the sensor to dry before installing. If there is a wierd whine comming out of your engine bay it's that it wasn't completely dry. This should go away after a day or two. Also let the engine idle for a few mins and warm up.
  20. Ok guys This is a how-to on a basic clean-up that covers one part thats overlooked most of the time. This is the IAC valve. For info on the IAC valve just go here. http://www.2carpros.com/articles/how-idle-air-control-valve-works Anyway this write up is for a 3.0 v6 tribute but the process is similar on most vehicles. Here's what you need Clean dry rags Carburetor cleaner (you can easily find it at the auto section in arpico. There are a few brands o choose from and cost between 450-600 a can). Basic socket set with a ratchet. (I used a torque wrenchto tighten the bolts to spec but a ratchet wouldbe fine). A slight engine clean up. With the engine running and the air filter out spray some carb cleaner into the air intake. Use 1-2 second bursts. You engine will act like its about to stall, when that happens just stop for a couple of seconds till it gets back to normal. While going this have someone rev the engine between 4-5000 rpm. You should see smoke comming out of your tail pipe. I would not breathe in the smoke if I were you. After revving it for 1-2 mins you are good to go. This ends the carb cleaning part of the tuneup. Cleaning the IAC valve. With the engine cooled down locate your IAC valve and unplug the wiring harness on the back of it. Proceed to remove it and inspect it for build up. You should see a lot of carbon buildup if it has never been cleaned. Take your carb cleaner and spray the inside of the valve. The carb cleaner can should come with a small straw that goes into the nozzle. Use this to spray the inside of the valve and break up the carbon deposits. Spray carb cleaner for a second time and shake the IAC valve dry. Also make sure you spray carb cleaner and cleaned the contact points. Next, look at the area on that the valve was mounted to. You should see build up down the two holes. Spray carb cleaner and clean it. The next step is something I skipped but needs to be done. Ran out of gasket maker today so it will have to wait till tomorow. Remove the old gasket where you set the valve using a flat head screw driver. Always be gentle as the metal on these parts as the metal is soft in comparisomn to other areas. Use the gasket maker to created a new gasket in the recessed area where the old one was. Once the gasket sets (refer to packing for those details) place the valve back and put the bolts back in. Always hand tighten bolts as much as you can and then use the ratchet. This will help prevent stripped threads. If you have a torque wrench then use the manufacturers specs if not tighten it softly and make a 1/2 to 1/4 turn. Plug the harness back in, start the car up and let it idle. If you valve had a lot of build up you would notice a much smoother idle. Either way cleaning it up is good as it will extend the life of the valve. If you have any questions please do ask. If I can;t answer them some one else should be able to. Also if you like these posts and find them helpful please let me know. It will help me know that i'm not wasting time writing these up. I was going to clean the EGR valve too but ran out of time today. I will update this post whenever I get to it. If you don't see detailed pictures on this post it means I haven't loaded them as yet. PLease check back. I'm having some issues with photobucket today.
  21. Thanks. Just note that using rubbing compound on a dash isn't something that should be done frequently. If your dash does not show signs of extensive discoloration you can use a good vinyl and plastic cleaner. Getting ready to paint my exhaust so I guess i'll just make a thread about that when i'm done.
  22. for those of you who may not know what you are looking at in the pics. The gray strip that resembles silicone at the top of the picture is actually a pretty deep layer of dirt.
  23. Here's another DIY for anyone who may have scratched or sticking windows. The reason for me posting all the DIY/hot-to articles recently is because im in the process of restoring everything in the tribute. I'm waiting on some mechanical parts to arrive so I thoughts I would handle the rest of the stuff during that time. If you want me to post infor on changing the mechanical parts just let me know. I doubt that there's another tribute owner so I won't post that info unless requested. Also if you want be to stop making a million diy posts please do let me know. If you want more please comment and also share your views if ou feelyou have a better way around things. Anyway, when I bought the tribute I noticed that the rear windows were sticking and all four windows up front were scratched. I decided to have a look today to see what the problem was. What I found was the weather stripping coated in sand and dirt that almost looked like mud. If you have the same problem or are noticing a few scratches on your windows it would help to check your weather stripping. It would also be good preventative maintainence too. To remove the outer weather stripping on the windows simply take a flat screw driver and wedge it between the weather stripping and the metal on the door, taking care not to bend the weather stripping or scratch the door. Pry it upwards and once you have a bit of it off the door just pull the rest out with your hand. One thing you should do is to make sure you dont bend the weather stripping. After you have removed it just wash it down under a tap and use some dish washing soap to wash the side that makes contact with the window.Just gently rub the soap in with your fingers and don't scrub. Scrubbing will damage the soft suede like material that makes contact with the window. Once you are done cleaning all four just install them right away. You could let it dry but it's really not needed. Before installing make sure you clean the area where the weather stripping was. You would notice a lot of dirt. After your done clean the windows too. Here are some pics.
