Everything posted by Sifaan
What To Buy?
If you do 30km/day, 5 days/week, 52 weeks/year, that's 7800km/year; let's say even 10,000km/year with some leisure travel... A car that does 13 km/l will cost Rs. 96,000/year on fuel A car that does 9 km/l will cost Rs. 140,000/year on fuel For saving less than 50,000/year on fuel it's not worth to chase after a car that can do 12-13 km/l. Especially because "fuel efficient" cars command a premium price, so the 13km/l car will probably be older than the the 9km/l car you can buy for the same price, which generally means more maintenance costs (although of course that depends a lot on how the individual car has been taken care of)
Meter Panel Symbol And Abs Symbol Operation
Interesting... if he had indeed tampered with the odo, he was "smart" enough to do it months before he sold the car (or it might have been tampered before he bought the car) and it seems that you've managed without ABS for 50,000 kms? if there is indeed a fault with the ABS, you've been lucky to not have an accident!
Good Car Fragrance / Freshener
Why a new thread..? you've even posted on the old thread
just wondering... how did you find this out?
Allion Nzt 260, Year 2007 Black. Worth For 4.8 Mil??
Generally automotive paint was either solid or metallic. metallic looked nicer and was more expensive. more recently, there is a "improvement" of metallic that is pearlescent, which is even more expensive. http://en.wikipedia.org/wiki/Metallic_paint BTW I don't know if this is the correct explanation for "pearl white" in Sri Lanka
Is Californican A Paid Stooge By Sri Lankan Hybrid Importers?
actually, he didn't say there's logic in what you said. He did say "I would explain the logic in it" but "it" referred to the preceding "Also I highly doubt the "almost all" hybrid owners will take their cars to the agents."
Difference Between "d", "b" & "s" Gear In Vitz (1000Cc)
The first response is correct; beyond that is just details. Also the wiki link on the first post on 2nd page explains the various modes in more detail
Nissan March K11
Interesting, I'm not even 5'8" but never was comfortable in the K11. Maybe it's just individual anthropometry differences; hard to imagine how the Euro version had more foot space than the JDM (unless the Micra front seats were moved back compared to March)
Under Bonnet Heat Shield
Interesting point; never thought about it from that angle. What purpose does it serve in a cold country? Help the engine to come to ideal operating temperature quicker? BTW doesn't it also have a noise muffling role?
Recommend Good Agencies That Import Hyundais.please!!
If it's only sold in Korea then you are going to have a bit of a problem because they drive on the other side of the road. Maybe life is simple with Hyundai, and the parts are indeed matchable either from a petrol car or the Tucson, but in my experience (a Citroen) it's not as simple as that. For example, I have the EW10J4 engine which is also available on the 406, but there was some engine part (can't remember which) that actually was destined for the 607 (which wasn't offered with the EW10J4) So you really need to check this in detail; e.g. do the fuel delivery systems (fuel pump, high pressure pump (presuming it's common rail), etc) match the Tucson as well? And BTW I would be very surprised if the wiring / ECUs are the same for petrol/diesel.
What Do U Think About 3M Tint..?
The 3M windscreen tint has (or is supposed to have) 70% visible light transmission; so it could be argued that the light from the headlights should reduce by about that amount. However, glare is more complicated than just light intensity - e.g. is worse with dirty windscreen, if you are wearing glasses (esp. with fingerprints) so I don't know if the glare reduction will be more or less than 30%. In my case, maybe the glare is less, but it is not by so much that I have even thought about it until now And BTW it wasn't part of the decision making process for me, and I was not even aware that it was marketed/considered as a benefit of tinting.
Blame It On The Horses
Interesting story of how different countries evolved to drive on the left or right http://users.telenet.be/worldstandards/driving%20on%20the%20left.htm (sorry if this has been posted before)
well... that would be engine in sports mode rather than transmission in sports mode From an electronics perspective I don't see why they can't build a ECU with 2 maps in the ROM (even if it means a bigger ROM) and have it switch, but mechanically I don't know what the impact would be of the ECU pushing a different set of parameters on an engine that is already running. Since the technology for variable valve timing and lift exists, maybe even that is possible... perhaps the cost of engineering all that is more than it would cost to just have a bigger engine?
what do you mean? of course the transmission has to shift up at some point (unless we're talking about a single-gear tesla roadster) if you mean not having "fixed" cut-offs, I was only using fixed numbers to illustrate the difference; I don't know if it was the case in the past, but I doubt if any modern autobox uses fixed rpms for shifting. e.g. in my manual it says the ECU selects the appropriate gear based on "style of driving, route profile, and vehicle load". Sports mode then "influences" that decision-making to shift up later (and down earlier)
huh? Let's say (taking a simplified case) that an autobox in normal mode will shift up everytime the engine reaches 3000 rpm (and the rpms drop to 1000), and in sports mode will shift up everytime the engine reaches 3600 rpm (and rpms drop to 1200) Unless you are happy to drive slowly in 1st gear, how can you stop the engine exceeding 3000 rpm if the transmission is permanently in sports mode?
I'm not exactly sure how this works... but now I've referred my engine (PSA EW10J4) specs and it says max torque of 190 NM @ 4100 rpm and max power of 100kW @ 6000 rpm. I don't think the ECU allows it to go upto 6000 rpm even on Sports mode (except of course on 4th gear). Next time I have a clear run I'll take a look at which rpm's it shifts up on Normal, Sports and Manual modes (or for everybody's safety, get my wife to hold a camera while I keep my eyes on the road!) because then you have more vibration, more noise, more engine wear, more fuel consumption; and most people don't want to pay that price for the benefit of reaching 60mph a little sooner. (autoboxes already take a bashing for being less fuel efficient) the throttle position (I presume you mean accelerator pedal position) determines what speed the driver wants to go at; it doesn't determine how fast the car can respond to that need. well, it does increase the effective power of the engine by shifting the power band to the right.
I think I understand your confusion... One of the ways of talking of car performance is the 0-60mph time (and IMHO it's a more useful way than just talking of the engine HP (which is anyway only at a particular rpm), because the real application of that power depends on the car weight, transmission, aerodynamics, etc.) On Sports mode, the car will deliver a better 0-60 time than on normal mode. And it does it (in the case of non-CVT autoboxes) by exactly the same means as you would in a manual car if you wanted to reduce the 0-60 time: delay upshifts. However the ECU won't redline the engine like is possible with a manual
I don't recall it being that much of a difference, probably 500-1000 rpm more (for conventional auto; dunno about CVT) but that's if we're talking about switching threshold. if we mean engine rpm at a particular car speed, then the difference can vary a lot (especially when the normal mode has just shifted up, and the sports mode has not yet shifted up). by "do it with your foot" did you mean kick-down? that's different (purpose and implementation) else not sure what you meant?
true; there are no discrete changes because there are no gear wheels; but the gearing ratio is still being changed by the CVT box when you accelerate, ECU has to balance how much to deliver from engine increasing rpm and how much to deliver from gearing ratio changes. In Sports mode, the balance can shift to allow the engine to develop higher rpms
Nissan March K11
Have you had a test-drive on K11? We had a K11 (it was wife's from before we got married) and it's horribly cramped unless you're short (even my wife drove with the seat as far back as possible) and the pickup on the 1l engine + autobox is terrible. and considering my wife bought it thinking "small car = fuel efficient", it was a total fail.
generally, Sports mode on an automatic means the ECU changes up at higher RPMs than what it would normally do. So you have more acceleration at the expense of more more noise, more vibration, more engine wear and more fuel consumption.
everyday car vs. rarely use?
Will Hybrids Fail Or Succeed In Sri Lanka?
http://green.autoblog.com/2010/06/13/toyota-prius-blows-past-sales-expectations-in-india-with-80-unit/ Bit old news; Toyota was initially expecting 12 units a month, in a market the size of India... and they were pleasantly surprised to sell 80 in 3 months. According to the news on the tax revision, Sri Lanka imported 3000 in 3 months (I thought it would be more given the number visible on the streets). But even if these cars in India are running fine 5 to 10 years from now, it's still not comparable to Sri Lanka (brand new vs. recon; agent support vs. none).
Hybrid Maintanence
do they calculate this by testing the model (meaning it's more practical to establish test conditions) or by testing the individual car, e.g. when renewing MOT, (so you can penalise those who are not maintaining the car properly - e.g. repairs to EGR, particulate filters, etc)
Well, we can't count Sri Lanka as one of those 80 countries (except maybe the 1st Gen ones) because the cars here have already been counted when they were sold in Japan. If Toyota is selling hybrids in a country that means the model is climatised and the tech support is available. Taking a car designed for japanese conditions and running it here is a different story. Do you have any success stories for Prius in scenario like Sri Lanka - where they are using used cars from another market + no agent backing?
