Everything posted by Sifaan
Recommended Tyre Pressure (in Sri Lanka)
Well, I wasn't planning on taking the tuk tuk guy's statement at face value Once I get the tyre pressure gadget I ordered (on ebay) I'll be better equipped to play this game! This site has an interesting practical test to check if the pressure is OK.
Triptronic Vs. Auto
Well, if the changes did happen at the same set speeds that would defeat the point of putting in the extra bits to call it a tiptronic plus, some have a "sports" mode that adjusts the gear change speeds for more performance (basically, delays changes so you get more performance, at the expense of fuel economy, engine noise, engine wear and comfort) Have also seen this on a Corona Premio. That "S" would be the sports mode (as above), and "B" is for driving in hilly conditions and will employ engine breaking to reduce wear on brake pads. Edit: PS. If you have an overdrive button, then you can turn overdrive off when going uphill/downhill. You get better pickup going up and engine braking going down
Triptronic Vs. Auto
I guess this may vary by manufacturer/model, but the ones I've seen don't actually rely on the driver to change gears, but rather give the driver the opportunity to change gears. The difference being that, if you are on a manual and you slow down too much without downshifting, the engine will stall. On a tiptronic, it will downshift if there's a risk of stalling. Similarly, on a manual you could run the engine at very high rpms but the tiptronic would shift up if the rpm went beyond the "safe" range. As for advantages of tiptronic over regular auto; with auto, the gear changes are at predetermined speed (some balance between fuel economy and performance). with the tiptronic, you get the benefit of manual (able to change gears to improve fuel efficiency or improve performance, depending on what the need of the moment is) without the hassle of having to be in manual mode all the time. basically you get the (more or less) best of both worlds
I was once in a Tuk Tuk when he was pumping air and he asked for 34. I was a bit surprised and asked him about it and he said smaller tyres need more pressure, and that lorry/tractor tyres need very little pressure (anyone have any experience? and what's a typical pressure for a motorbike?). This seemed a bit counter-intuitive (bigger tyres means bigger, heavier vehicles, so shouldn't they need more pressure?) but I didn't press the case. Of course, even if the Tuk Tuk guy was right, a lorry tyre is bigger than a tuk tuk tyre in terms of rim size, width, and overall diameter, so it's not clear which parameter should increase to reduce the required pressure. (e.g. even if you changed from R13/R14 to R15, presumably the overall diameter is the same, or at least similar). Edit: The plot thickens; these sites (1, 2) suggest that tyre pressure increase if you increase rim size, and this one suggests you decrease :S
I'm a newbie at this, so I may be totally off the mark here... is it possible that there is some fault in the suspension that is being masked by lower tyre pressure?
Car Covers
Thanks VVTi / RangeRover, will check out Armorall
Car Covers
Thanks for the links Summary seems to be A covered shelter is a preferred option to a car cover (not an option since the car is parked on the road during the daytime ) Cheap stuff (umbrella like material) doesn't last long Need to be careful (esp. if there is mud) to avoid scratches Water protection is iffy (waterproof ones don't protect from ground moisture, breathable ones let the rain through) Interior protection (at least partial) through window shades or commercially available protectant (what are they?) If you do use a cover, make sure cats don't piss on it covers with interior padding will (probably) not scratch the paint Except for a slight reference by VVTi, earlier discussions haven't really focused on UV protection of interior (plastics, leather, etc.) and rubber beadings though... so still would like to here any experiences in that context
Insurance Policy After Selling A Vehicle
Last month, we got a credit note from the insurance company that we can use to get a discount when we buy insurance for a new car. They did not offer us the option of getting the refund in cash. In the policy details, i noticed that some additional covers (e.g. workmen compensation) will not be refunded (in any form) if the policy is terminated. Same may apply to other covers (accident benefit, etc.). But few months ago a guy (I was checking out the car he was selling) told me that he was able to get a cash refund when he terminated the terrorism cover portion of his policy. If he was telling the truth then you might be able to get some part of the refund in cash.
Car Covers
Has anyone had any experience of using car covers to protect cars from UV damage (e.g. to reduce ageing of interior, paint fading, etc)? or are the covers available locally just for keeping off dust/water? (I've not really checked them out myself, but noticed some on ebay that claimed UV protection) Given that not everyone has the luxury of covered parking, covers with UV protection could help preserve the car in good condition, right? (of course, how useful it is depends on how much time it is parked in the sun vs. driven in the sun and someone once told me he doesn't like to use covers because they scratch the paint)
Didn't know such things existed. Thanks for the tip - I'll get myself one Well, I was only thinking of the tyre wear and fuel economy perspectives, which are already good enough reasons to have correct tyre pressure Well, all other things being equal, I would trust the manufacturer over the agent But "local conditions" are one of the unequal thingies - e.g. certain service intervals tend to be more frequent than manufacturer spec because of temperature/UV, dust, quality of fuel, etc. That's why I was wondering if our climate had an effect on tyre pressure... from what you say, if there is a change, it should be to a higher pressure (because manufacturer spec is cold reading, and most of us would measure at a shed, which means a hot reading) Anyway, thanks for the insights!
Well, that's the confusing bit... because the pressure the agent recommends is LOWER than what the manufacturer / websites recommends (but those are probably calibrated to colder climates, if that makes a difference). So, let's say recommended pressure is 30. If I go to the shed first thing in the morning then maybe I can pump air for 30... but if the car has been running around all day and is hot, then 30 would be under-pressure, isn't it? So we should go for 31? 32? more? Cheers
Doesn't the recommended pressure vary with tyre sizes (mine are 195/65 R15)?
Hi! (My first question on AL ) There are websites that give recommended tyre pressures for various vehicles. Can these numbers be used as-is in Sri Lanka, or should they be adjusted for the climate here? e.g. the Agent says they usually advise 24 (front) / 26 (rear) but the website suggested 34! even for the previous car the recommended pressure we found on some websites were higher than what was recommended here (but I don't recall the numbers now) Thanks /Sifaan
