keilysmith
Everything posted by keilysmith
  1. If this is your daily run, or use for long trips is very hectic and disturbing noice. Up and get bored quickly. When you went to Colombo and Kandy in mid-night to return to CRX with a scarf performance. And I had a small back seat in most of the time.
  2. During the final drive of 100 km terrible, look at the orange light of pre-heating (as a coil) is a Dashboard Mk 6 Transit began to flash. The engine was fine and there were no other problems visible or audible signal. I managed the van home (we were only a few kilometers) and tried to start the engine again. It started for the first time and now it seems to light. In fact, the van seems to be working correctly now.
  3. When the oil comes on,actually, it depends on when. Oil always return to the light when you start the car for a few seconds of the test lamp. You must always be careful, because if someone lights come on, you must have it confirmed. If you do not, and this problem is to warn is really happening, you must drive ignorance until something worse happens.
  4. when the car is parked and stored ... oil accumulated in the top of the engine slowly begin to seep into the combustion chamber. that keeps the car parked overnight there a certain amount of oil collected in the room. And when you start the engine in the morning all the collected oil will burn a bit of blue smoke. When the oil is burned the smoke is significantly reduced. In some cases, you can barely see the smoke at all.
  5. I had to replace them and I had to change the front suspension LHS, jolint hp, ball bearings and quiet. Although, after all, still had four-wheel alignment and handling problems at high speeds and sometimes shaky Sanjeew similar effect. When I took it back they told a different mechanism to replace shrubs.
