hatharasinghe
Everything posted by hatharasinghe
  1. Hi Guys, Anybody have an experiance on using this Ferentino tyres , is it good to use , plan to buy tyre set for Allion Car. Kindly advise.
  2. Hi Guys, kindly share your experiance of Ferentino tyres , is it relaible for car or light vehicle , Will it be run as others without issues ? any comments highly appriciate.
  3. Thanks for the information I check it on other places. Have a nice weekend
  4. Thanks for the kind advise I check on it.
  5. Thanks for your kind advise Toyota Lanka quote 190K for the compressor only with fixing and all it around 220K
  6. I have second hand Premio car and recently i noticed when i speedup 80 or more ( it happened at Highway) AC automatically turned off but blower works and once low down the speed to 60 or below its again working. Then showed it to AC repair place they showed one sensor has carbon deposited and its not working so replaced it but the problem is still there. Could you pls advise me what to check or replace , Hope your kind advise. Have a nice day Roshan
  7. Thanks for your kind response in short period.
  8. Pls advice me , Does a brand new car ( buy from company or car sale) require a wheel alignment? before it use Thanks with best regards Hatharasinghe
  9. I formatted in fat 32 but the same result same message appear, any idea to sort this pls help.
  10. Ok today i try it and let you know if it works great. thanks for the information
  11. I checked memory cards but couldn't find and adapter i could find and only M2 micro memory cards to be insert the adapter cost is just 50 rs and memory card cost is 1000 for 4gb . But once i insert it , there is a massage " The heart does not correspond to this memory stick" i get this from google translate , so what is the error did i insert wrong card or such , the card slot and this M2 memory adapter fix without problem , pls advise me thanks with best regards roshan
  12. Thanks for that option also sure it save money.
  13. Thanks for the important informations I'll try to find this kind of Memory card and try the CD also. Hope i can buy this card from Colombo if you know a place pls update me. Have a nice day
  14. Thanks for the information i checked with google translator actually what i need only two things 1. what is the memory card we should use as it seems something uncommon size ( more length than usual ) 2. How can i copy files( MP3 etc ) to the HDD i don't have data cable and is it available in here Pls help me if you know how to operate this waiting for the kind response. Have a nice day.
  15. Can anyone let me know where can i get the english manual for this car setup its fully japanese . Thanks with best regards Roshan
  16. several famouse garages checked no one could find it as it happen after long drive in normal condition nothing wrong once i drive around colombo areas normally 20km up and down then nothing wrong at all .some garages kept the car couple of days to check but couldnt find. and some expertise who appear on TV also couldnt find.
  17. Sometime this information will help to you , if you use Kia Spectra, Hyndai Accent ect... or sometime this may happen to any other models also. I already post this matter 2 yrs ago and got lot of technical ideas but couldnt get exact result. I had a Kia Spectra car and once i drive long distance (i go Badulla lot of weekends from Kiribathgoda) once i drive more than 100km then suddenly there was a problem the car is not moving fast though i push the Accelarator sometime speed under 40Km/Hr .And if the car stopped for a 15min then drive again can do normal drive at least another 10KM and again the problem started. So below repairs done. 1.Replace Injectors 2.Engine Tune 3.Ignition Coil 4.Checking all the fuel line and cleaning fuel filter and pump 5.Throttle body And lot of relating repairs done at famous garages and company. But no improment this only happen only after 100 + KM drive .No one could find the exact answer. Finally one garage guy at Badulla told me after hearing my story , he had previous experiance all Korean Vehicles fuel pump get problem on after some years specially the inside coil will not able to produce necessary action to function the fuel pump properly when it heatup pump works out of normal funtion. So replaced it with Japanese good one and after that nothing wrong and driven it as before. Hope if anybody suffer this kind of matter pls check this pump. Normal condition it works but after get heated its not working properly.
  18. Thanks for the valuble comments
  19. I need to know if this car has Triptronic facility and what standard for "S"at gear position is it sport mode or something else .Pls advise me.
  20. Any idea where can i buy it in sri lanka or if you bought it from ebay could you pls let me know your exact brand to avoid any trouble.
  21. Thanks iRage i downloaded,its 260 series i can get translation of some important oages, Thanks for the quick response.
  22. Dear All , Any luck to get this user manual pls advise me. thanks Roshan
  23. All Friends, I imported premio 2014 gsuperior car but i need to put original beige colour seat cover set and carpet set pls let me advise the better place for that and any luck to have price range . thanks with best regards roshan
  24. Dear Friends Pls let me know where can i find a better place to repair car doos winding motors and related parts specially i need a place around Kandy area if not pls let me know even darly road . Thanks
