Tharindu1
Everything posted by Tharindu1
  1. That's very true about L*l alaw*tta. The only good thing about his place is that the mechanics are specialized to a specific area so they can master that...
  2. Starlet EP82 does around 12 kmpl in Colombo city and did around 17 kmpl outsation for me.
  3. After the installation the system actually works with some bass because only one speaker was erroneously connected. I have double check later because I felt it should produce sounds better than this. Other thing was when the job was completed it's almost 7 pm and there were not much time left to play with the system at that time. So only chance that I got to experiment was after going back home.
  4. In the speaker there are two types of pins so you can't go wrong with that, but the issue was the original wire which was came with the speaker is a short wire so you need to connect an additional wire to connect the speaker and the head unit. So you need to connect that wires with the correct color matching. Most of the times the '-' wire was marked with a black strip and the '+' wire was marked with a red strip.
  5. Hi All, Recently I have installed a JVC setup from the Gi*Ber* & Sons and I have noticed lack of bass from the system (clarion speakers). After the installation their opinion was to have a speaker box to get more bass. Anyway when I go home I double check the speaker wiring by removing the head unit again and surprisingly the + and - wires of rear left speaker was altered. Then I installed the wires correctly and the problem solved and now I have good quality sounds. Just for your information, If you also having less bass then the first thing you should do is check the speaker wiring with + and - terminals from the speaker to head unit. BR Tharindu.
  6. Thanks for the information.
  7. Hey all, Anyone know the contact number of C.T.Lionel radiators? Address (Where is it situated ?)...?
