Dinuk
Dinuk's Achievements
  1. I know a person, who have done this.....
  2. I think he was driving the Allion.... not the BMW
  3. Of cause... you can't get it without paying 75k. I'm talking about reserving the number without the valid documents of the vehicle... When you are reserving the number you have to produce original documents and receipts that you get from the clearing agent. you don't have to pay 75k when you reserve the number. But you can reserve the number before the vehicle gets here by throwing some cash..
  4. Happy new year to all.....
  5. Dinuk
    Vvti
  6. definitely this is not a Japanese part... Check for any damages at the CV joint.. If there is not... replace the boot with a new one... or replace the CV joint... when buying parts always go to the importer... but some importers has duplicates with them.
  7. Go for a HR-V.. And I can't remember any difference between pre 2000 and post 2000 models,
  8. To reserve a number you have to produce valid documents with a request for the reservation.... But I think you can do it with the help of few hundred bucks...
  9. And still running in good condition....
  10. Yes ripper I agree with you.. But my point is, do you afraid of rotary engines? I'm sure you are not... So, why are you afraid of hybrid engines??
  11. Try Semini Motors, Panchikawatta..
  12. Just because it is TOYOTA.
  13. Yes, Ripper is right... And I also dont think a fault hat failed the vehicle from the emission test won't be corrected by ECU resetting. (You haven't mentioned about a emission test fail...) An ECU always try to use a closed loop to control the fuel delivery. Unless the ECU running on safe mode or at several engine situations, such as cold start or full load conditions, the efficiency is maintained at highest level. performance vice it may have a effect.... And another thing... high performance means low economy..... resetting ECU and driving economically will reduce your fuel cost..... but I'm sure that will not be a large measurable figure....
  14. Yes... after all day promoting.... this is the time I log in to the web and do some Ninja tricks....
  15. I think these are the only poll you can trust in Sri Lanka.... cause you vote for what you really think..... Wattala....
