flashmark
Everything posted by flashmark
It was 28k when I imported it in year 2012. Now it is 43k beacuse lat two years I didn't drive it regularly.I think it is never changed.When I asked for A*W technician about ATF, they said change it after 80k mileage.
When accelerate bit, RPM increase unexpectedly (Not like before). Moving more than expected speed. Recently replaced Airfilter and did a tuneup 6 months back
Red, Green Or Blue Color Coolant Suits For Suzuki Swift
flashmark replied to flashmark's topic in General Automotive
Thanks All. -
Hi, When driving my suzuki Swift (2010 beetle) now I'm experiencing a pick up issue. Sometime when I accelerate bit, the car speed increases rapidly. Earlier it didn't happen. When accelerate bit it increase speed slowly as expected. Now car mileage is 43k and I never changed ATF oil .Is that the problem?
Is that Ok to switch from 3M coolant to Getsun Coolant without flushing? In terms of brand, what is the best? -
Fortunately, there are no damages to the chassis, buffers or engine.The right side wheel fully damaged(including suspension and ABS)There are no critical damage to other parts.
Hi, Recently I faced and accident in southern highway and because of that my Swift (Japanese) damaged (Airbag, ABS, Suspension…and body).I want to know which is the best place to repair the damages (Since I’ve to replace Airbag, ABS, Suspension…etc).Can you recommend an Associated motor (Lanka) Pvt Ltd (Full subsidiary of A*W)? Seems like they don’t have man power or equipment to repair? Some people are saying that is good and some others saying bad. That one is located closer my living area.That what I'm looking for your recomondations. Can I trust that place?
How Do I Use "shift Lock" - Suzuki Swift
But sometime I'm expriencing that I've to press that button to change the gear even when car is in starting mode.Why is that? -
Hi All, I've a question how do I use "Shift lock" - Suzuki Swift. I've to press the "Shift lock" button to change the gear after parking the car.Can someone explain how to use "Shift lock" and benefits of it thanks in advance, F
Speedomeeter And Fuel Meter Lights Blinking
Thanks All. It was resolved after cleaned connectors. -
Any help? -
Hi, I didn't use my suzuki Swift (2010)about one month.When I started my car 3 days ago, I've seen that the speedometer and fuel meter light blinking. Speedometer or fuel meter not working.Fuel meter shows that its empty.So I fill few liters fuel and after a few Km drive it comes to normal. But yesterday again, I've seen that issue again (light blinking and meters not working)But this time its doesn't come to normal.I drove about 20Km but the problem doesn't resolve(earlier I thought that happened because of the battery.But my car battery is new 4-5 months old. Also battery should charge after 20km drive) Please help to resolve this problem. Thanks in advance
Hi, I'm going to import a "2 Din Car DVD Player built-in GPS Navigation Stereo Radio TV" setup from china.Before that I want to make sure is this fit with my Suzuki Swift 2010(japanese) dahboard.Please help me.Also want can I remove "pocket" from dashboard, easily? Please see attached photos. thanks in advance
Hi All, 1.Could you please explain the usage of Shift lock in Suzuki Swift? 2.Sometime I've noticed that gear can not change from "P" position to other positions (Eg "D").To move the gear into other postion I've to do it while pressing "Shift lock" button.Is that normal? 3.I heard that shift lock useful to fuel economy? Is that correct? Please explain how to use that function properly. Thanks
Any help, pls?
My Car Makes A Clicking Noise But Won't Start (Starter Motor Not Working)
flashmark replied to flashmark's question in Mechanical problems
Is there any way repair and use the battery temporally? If I've to replace the battery what do you recomned for using a car rarely? Am*ron seal type one? thanks -
One of the mechanic said that continuous trying to start may damage the sensor which price is 3 - 4 laks.Is that correct? -
Thanks. If it is a starter motor problem, how it started using other battery ? -
Thanks all. Any possibility to dead a well charged battery because of loose connection or something similar (short) ? Why this issue occurred when manually turn ON and OFF the autolight switch? (I've done it before but the first time after the service.I've doubt whether this is service station fault) If battery is faulty any possibility to use it after high charge using any other mechanism? -
Hi, Yesterday night I faced starting issue with my Suzuki Swift (Japanese ZSC71S).After traveled about 20 km I stopped the car and switch ON the headlight(Autolights) manually. After 2 mins time I OFF the auto light manualy and tried to start the Car.But it won't start.Starter motor not working at all. I heard some noise (short?) when trying to start the car.Light,CD player,power shutters ... didn't work properly (malfunctioning). But sometimes all the things working properly but not starter motor. There are no sign in dash board for battery failure.Then used the jumper cable to start the engine.It started properly.After another 10-15 minitues drive I stopped the car for parking.After that again it not starting (starter motor not working) I didn't drive this car regularly (once a week about 20-30Kms) and did the first service few days ago. So what do you think about this issue? Is it sign of dead battery? Alternator issue or some problem in electronic system? Please help me thanks
Hi, I need your opinions about below questions for my Swift (Japanese beetle 2010).Thanks for your understandings . 1.What should need to do in first service? What is the recommended place? 2.Recomended engine oil? 3.Do I need to change Auto transmision oil? 4.Why some noice occur when start to move? 5.Is that digital meter reading for fuel efficiency is correct? 6.In which situations we have to use "N" gear and "L"? 7.can we change "D" to "S" while acclerating a car? (overtaking) 8.What are the recomonded speed and RPM for better fuel efficiency? 9.Does that gradually increasing speed and minimize the breaking save fuel? 10. Is that ok to keep car without starting 1- 2 weeks contnously? 11. Any other recomondations
I found a one in ebay.Do not know about the quality .It will cost around Rs 2500 from ebay. http://www.ebay.com/itm/PVC-Coating-Waterproof-Car-Outdoor-Full-Cover-Layer-Silver-Color-Size-S-XXL-/120886815704?pt=LH_DefaultDomain_0&var=&hash=item1c256a6bd8#ht_3329wt_922
I'm looking for outdoor car cover for Suzuki Swift. Can you recommend any cover and where I can buy it (and price)? I knew that some car covers damage the paint of vehicle.Is it true for all covers? Let me know your feedback thanks
I'm looking for night vision reverse camera for my Suzuki Swift. Anyone using below reverse camera? Let me know the feedback and what do you think which one is best? http://www.ebay.com/...#ht_3250wt_1185 http://www.ebay.com/...8#ht_3335wt_952 thanks
