miniace: email sent for GPS waypoints that you have
Even my device has a limitation of 500 waypoints / track. However, you can have mulitple tracks and as such i have over (at the last count) over 500 tracks. If you need to you can save the tracks in parts. Some on the GPS internal, SD card and some i have archived it to the latptop. When needed i will transfer it back to the device.
When looking to get a GPS keep in mind to see if all data is transferable both ways (PC -> unit -> PC). Also make sure you have some memory upgrade methodology (i.e. SD slot etc). Most units come with just a small inbuilt memory amount, once you get in to it, this will fast run out and if you did not plan for it, you are toast. Especially when you start to load topo or geographical data ...
Applications such as MapPoint/Streets and Trips etc can talk to a GPS real time via NMEA standards (check if the unit supports this protocol). Even if the unit is USB connected the you need a USB to COM bridge as NMEA is a COM standard.
neXgen: Quote - "i did come accross a software which has SL maps." - Can you point me in the correct direction for this software? tx
Devinda_Z: CJ8 are generally known here as Scramblers, same concept as the CJ5 and 7, very stable when built up due to the longwheel base. However, difficult to manouver round obstacles without body damage.
