Everything posted by Amila G
Tyre Prices
If anyone is going to get bridgestones don't buy from autodrome directly. Their max discount % is less than that you can get from a dealer. I got my turanzas from a shop just a few blocks down the road from the autodrome for a much less price than the autodrome's with the max discount applied. When I went to the tire shop, they send 2 chaps to autodrome to get the tires with a cheque and they were back with the tires within 10 mins
Noise From Drivers Side Wheel
Mine also has a similar noise in back wheels and goes away after a couple of brake applications. Cause is the crappy rear brake liners. Cleaning the liners solve it for a couple of days. The solution will be to put in a good quality brake liner like FBL which I plan to do really soon....
Latest Fiasco Of Kia Motors
A cousin of mine ordered a Diesel sportage and was told the vehicle will be delivered on January. He's still waiting for the delivery and the latest delivery date they gave is in May and probably that'll change too...
- Camber Repair + Alignment
Yes I too had a weird issue as The Don mentioned btw is your car pulling to a side when going on a straight road ? Don't trust those computerized alignment buggers (from my experience ), take your car to car care wellawatte or better to auto wheel center in Panadura (if you live near) . Mostly outside wear happens due to excessive toe in on that wheel, and I doubt camber is the issue. If the camber is so wrong, you will be able to see that the wheel is tilted too much inwards or outwards. The camber is not adjustable on CE110, but alignment guys do it by either enlarging the bolt hole or slightly bending the shock (or mount I'm not sure) using a hydraulic puller. So take it to one of the 2 places I mentioned and explain the issue to them, hopefully they'll be able to solve it. On a side note, most technicians working in the computerized places knows only to adjust everything to show green in the display and sometimes getting the settings withing the green zone alone is not enough and it needs to be fine tuned. also check your lower arms and lower arm bushes. See if you could find any impact marks on them (may be an arm is bent) Good luck with solving the issue, mine drove me nuts
Tight Steering
Some mechanics tightens up the rack a bit when they do related repairs, if the rack is worn may be your one did that. Not sure of that on EPS systems. If the fluid level is very low you'll hear the pump groaning when loaded
2C Engine Re-Boring Help
Hi, My friend got a townace CR27 with a badly worn engine. Now the engine is fully dismantled for a overhaul and it's in very bad shape. Bore, pistons, valves everything is damaged and need replacing. But the mechanic is suggesting to re-bore the engine and then put a sleeve in and use new standard size pistons. I just don't get it. Why do you need to bore out and use a sleeve to get the cylinder to the standard size and when you can just bore it and use larger pistons ? AFAIK the engine does not have any sleeve originally. Could you guys shed some light on if there's any logic behind putting a sleeve to get the bore to standard size than using bigger pistons with a bored out cylinder ? He says the sleeves are of good quality, but I'm worried that they might not and they'll wear out faster than the original block. Is he trying to rip off ? Any help is really apriciated
Coolant
Let me add one more thing, Lots of guys say that the toyota coolant is great (and I believe it to be true) but I saw in somewhere that you should never mix it with older green coolants. So if you are going for toyota red make sure to flush the old one completely or it'll sludge up. AFAIK adding coolant (antifreeze) to the mix increases the engine temp as water has the best heat carrying ability but antifreeze prevent rust and we are getting the best of both worlds by mixing them. If you're worried about tap water get a distilled water can from a chemical (medical supplies)shop I think they are cheaper. as I remember a 4l can was around 500/=
Express-Way Updates
Not exactly the case. the green stuff increases the boiling point of the mix but too much of it restricts the water's ability to carry heat. So if you've got too much of it, it'll create overheating. http://www.challengers101.com/CoolantMix.html Anyway your engine is not getting enough coolant when it's running at high revs or radiator is not exchanging heat properly. If I were you, I'd remove the thermostat and do a short run on E01 again to see if the issue has something to do with the thermostat. May be it's not opening enough. (was it a genuine one that you put in ? )
Buying A New Car For Around 14Lakhs
They are to convey an idea.... in the Clarkson way. Yes it looks over the top but there's a message underneath. For a man looking for a car go take him from point a to point b any car would be fine. But for others there's more than that in car...
Kelisa... watch this to make up your mind...
Toyota 121 Vs Belta
Yes 121 s are over priced but for a reason right ? Reliability ? I'd go for the 121 from the 2 mentioned, FYI belta (yaris/vios) is in a lower class than corolla.
Suggest A Car With Following
see you've got a point there... he was a good motor cyclist but now he's got a back condition that prevents him from riding a bike Anyway I also couldn't think of a car to fit that criteria... so thought of asking you guys hoping some euro super mini would do that as used euros are lot cheaper here...
I thought they were worse on fuel than CE110 corollas, are they not ?
Thanks will check the punto. No he doesn't work on a fixed schedule and using the bus is an utter waste of time... like 3 more hrs a day than using a car...
From Ingiriya (abt 14km from horana) to colombo
Yup you are correct. May be he need to relax the fuel economy requirement. What really happened was, he had a townace CR27 that did like 12kmpl and cost him around 650/= a day. But with the diesel price increase it now costs like 900/= a day to run. So he was thinking of selling the van getting a car that'd put him to the earlier fuel cost.... But it s not a possibility it seems...
hmm... i was hoping something like a punto diesel will come close to the asked fuel economy... Anyway I'll ask him to stretch the budget or find a work place closer to home...
Will Hybrids Fail Or Succeed In Sri Lanka?
couldn't resist saying this, Corolla s success here is not only the toyota badge but rather its rock soild reliability. I (ab)used a '96 one for 3 years over 100,000 km and is still going strong... So you can't say a hybrid was successful here until they pass huge mileages without significant issues....
Hi Guys, Really need your help to find a car for a friend. The issue is below criteria. He travels 100km a day, to colombo and return from where he lives. 70 km out of that will be on roads without much of a traffic and 30km in colombo city traffic. Problem is he needs to do the complete trip in around 600/= for fuel. So that'll be around Rs 6 per 1 km. Therefore; if the car can run on normal diesel it should do 19 km/l For super diesel 23km/l For 90 petrol 25km/l For 95 petrol 28km/l ** Note the above are combined cycle Apart from that here are the other criteria : Price - less than 2.4 mil Re sale - should be able to re sell around the buying price in about 1 1/2 years Origin - Anywhere except china and India Maintenance - Comparable to a Jap one, but a bit higher is fine Durability/Reliability - Should be able to withstand bad roads on a regular basis without breaking down every now and then (toyota like durability is enough) AC/PS and YOM after 93 ish... Other creature comforts and abs+air bags => nice to have but not mandatory I'm scratching my head and the only thing that I could find was a diesel starlet but does only 16km/l. A diesel polo / golf would be fine but too expensive (diesel punto ?). So if you guys can give any suggestion, it s really appreciated. Note that max budget is 2.4mil.
Company Maintenance
it isn't a new car either.. it s 96 corolla it has an air bag. That guy said they can't take the steering off as they are afraid of breaking the air bag system. he told me he cannot fix it, if the air bag indicator turned on after putting the wheel back. The easy way to center the wheel is by adjusting the tie rods and he refused to do that either (when I asked to do so)coz his computer was saying all is well... But the car care centered it by adjusting tie rods. So after that no more pitstop for me... they are only as good as their computer and are like air headed monkeys who follow what the computer says. Don't have the technical expertise or common sense to do anything else.... I was actually thinking of straightening it by my self by removing the wheel (I downloaded the repair manual to find out the correct procedure to remove the steering too..) but luckily car care did it for me.
Company Maintenance
nope, atcually it was a bit off before the alignment so I told them specifically to center it. Yes I noticed the wheel leaving pitstop and came back in like 2 mins. But their so called supervisor or so told me that I have a play in my steering rack. (I had new mounts installed on the rack coz it actually had a play and tested it on the day before so I was pretty sure that the rack was fine.) He told that they lock the steering in dead ahead position and adjust the wheels according to the computer and if the wheel is off after that they cannot do anything about that. In that case I was the one who locked the steering so he told that they cannot do anything. But I actually triple checked the steering position with related to the column before saying ok to the tech to go ahead. I was so furious on that idiot and left without saying word. Anyway it was a free checking so I did not bother making a complaint. After that I went to car care and told the story and they centered the wheel without a fuss and is still centered perfectly . Also car care told me that the alignment was off on one wheel.
Company Maintenance
What ever you do never go to pitstop for alignment, car care is the place for alignment. Buggers at pitstop cannot even center the steering wheel after an alignment
Car A/c Unit
I too have the same mist issue on my corolla and the reason is air vents under the windscreen leaks cold air on to the windscreen. My DIY solution was to cover the windscreen air vents with a sellotape According to my AC tech, this happens due to the foam (cushions) lining inside the flaps that controls the air flow, deteriorate overtime and then the flaps can't re-direct air properly. The permanent solution is to re-do foam lining inside the vents/flaps but you need to take out the whole dashboard and spend probably 1 1/2 days. So for me sellotape is worth the hassle... also make sure to clean the windscreen with a good glass cleaner, sometimes the grease on windscreen worsens the mist issue
Engine Overhaul 2C
Did it include sleeves or just bore out the block and put new pistons ?
