Everything posted by FreakSL
Hey guys I have a Proton Gen 2 1.6L and , previous owner has put a 65Amps battery and I now its the time for a new battery, can anyone let me know whats the proper amhs I should for a 1600cc petrol car ? 45Amps is enough, 65Amps battery is too big and it doesnt fit properly to the battery rack in the car thanks
Hey people just need some information regarding Proton Gen 2 2007 model, I read that all the manual has issue with high RPM gear changing. mine has the same too, when driving in first and changing it to seconf RPM rise high, anyone who is driving a Gen 2 please let me know if this is normal ? thanks
Hey guys I noticed that when driving (after heating ) in traffic etc.. my clutch pedal become bit stiff and pick up power reduce, cold engine no problems car just runs fine, only when its heated up, clutch biting point is quite high, and I think these EG8's has hydrollic clutch which can't adjustable , do i need a clutch replacement or this is some other problem ?
yes its a single carb, It stays more than a second , i think I will have to check the AC idle valve
Hey guys , i recently noticed that when im driving with A/C on in my EG8, after sometimes (when the car heated up) idle up for few seconds and drop down again while driving , normally its on 800RPM with A/C and when while driving it goes to 1000RPM for few seconds and drop. want to know whether its normal or do i need to give any attention ? thanks
planing to go to a A/C repair place and show , need to connect all the lose and disconnet wires and check the fuse and what not, driving around without A/c in this heat is not funny at all... sigh !!!
now the A/C doesnt work, I heard a electric shortage may be some thing blew , normally when I switch on the a/c car idle become little bit low and there is a difference of pick up, now when I switch on the a/c nothing happen only the fan is working and it won't get cold at all, gaarah,
Guess I can go to a A/C repair place and tell them issue ? probably fixing up the disconnected valves and all, that dude told me that the original condenser which comes with the EG8 is not gonna work for the Sri Lanka , also how did you fix your one ?
gave a good tune up and cleaning to the carb from Upul in malabe , and gave a good service to the A/C, but when the A/C is on sometime suddenly the idle up to 2000rpm and stays for a minute or so and back to normal. also i can hear a noise of electric shortage inside the bonnet when the A/C on and changing the gears. the place i serviced the A/C said there are few disconnected valves , may be fixing that would solve the problem ? sigh
I told the mech to clean it and fix it as it is so i can take it to someone else who can see it and fix it , can you guys suggest me a place ?
mhh exactly dont know mechanic told me that , some parts are missing and one openning is closed , so the car power is very low, it become worst when A/C is switched on, hard to drive up hill with the A/c on. will it help with a repair kit ??
Sorry this is for a Civic EG8
Hey Guys im in a look to buy a good single carburetor , if anyone can let me know a place or someone who has it please be kind enough to pm me thanks in advance
thanks mate , tried hit add last sunday no luck , saw couple of ceres not in very good condition comparing to the price they are asking for.. i mean body and interior condition would not be tip top condition as for 15 odd years old cars , engine should be top condition
Hey guys im in the search of a good EG8 or a Toyota Ceres with the budget of 13-14 lakhs, is there anyone who knows something out there ? or any recommendations? i need to buy one as soon as possible thanks
nope its not a Hydraulic , it's cable. I replace the clutch like two months ago, so it cannot be worn out that soon, i dont think im a terrible driver to worn the clutch from two months this power loss thing starts when the car is heat up like going in the very slow traffic, I had the check engine light on few weeks back and the agent said there was oxide on the throttle sensor , after cleaning it the light didn't come back, but after some time the power loss thing occurred , I cleaned the MAP sensor as well i don't think it helped,
- 18 replies
- CB2
- engine heat
(and 2 more)
yes thats the problem also when its hot and going on a up hill power is so low and have to rev till 4-5 thousand RPM to keep the car without stalling , also notice that the gear change to first gear is bit difficult once this happen can it be a worn out clutch how to check if it that
- 18 replies
- CB2
- engine heat
(and 2 more)
guys I have a problem when the engine heat up (as in come to the normal temperature) on cold start car runs fine without no hesitation good pick up, but once going in the traffic for a long time (morning and evening rush hour) sometime feels the pick up is not enough as usual and need to rev more to gain the pick up ? is this is MAF problem or something any idea from the experts Car is a Proton Savvy Manual
- 18 replies
- CB2
- engine heat
(and 2 more)
coil pack and plug wires are also recently changed, it has a DF4 1.2 Renault engine. petrol filter is also changed recently , gonna change the air filter also
T belt changed not done even 10,000kms with it yet , problem is jerking come very suddenly and once i restart the car its gone...runs fine
fuel filter change not even 5 months , spark plugs changed , did a scan from the company ECU didnt have any error codes , company says that the problem haven't recorded in the ECU
Hey Guys , i have a small problem, car starts misfire suddenly (not very often, once in awhile) but after I restart the car , its gone is anyone else encounter this kind of a problem , car is 2005 proton savvy manual
Hey guys anyone has an idea where to get 94 Subaru Legacy RS spare parts ? i got couple of places but they don;t have T belt and Clutch plate , any idea ???
