thushanthatj
Everything posted by thushanthatj
  1. Noted. Thank you for the valuable advice.
  2. Noted.Thank you for the valuable advice.
  3. Thanks you guys! I'll keep u posted! ✌
  4. When he wanted to change the engine he went with the engine and gearbox since it was from the facelift, he got the complete engine and gearbox wire harness together. Anyway that's what he said. Just want to make sure it's in decent shape even with an accident as I will do a engine rebuild with bigger cams and complete exhaust from manifold. Let's see!
  5. ? yes very true, she looks nice with the makeup. Yes it's in Kandy and somebody told me that it has met with an accident. Maybe dats the reason he has put a new engine and gearbox. Why would anyone swap a 4AGE with another same engine.
  6. Hi, Yes with this lock down could not go and see the car. The seller has changed the engine and gearbox from his his old 4AGE with 5 forward to a new same 4AGE to a 6 forward which came from the facelift version. Here are some pictures.
  7. Noted thanks iRage. Can you also please reccomend me a place to do a port and polish. Thanks.
  8. Greetings, I am looking to buy a Carina GT AT210 and there is one available which has its transmission changed from 5 forward to a 6 forward transmission. My question is, it is possible to change the gearbox to a 6 forward without changing ECU etc? Is it a straight clean swap? Thanks for helping out. Cheers.
  9. Thanks kadsa98!
  10. Hi guys, Thinking of buying a VZR which has been put for sale for quite some time now. Its pretty beaten up and has been with quite a few hands. I'm interested in doing a full restoration on the car. Please advise/reccomend a good place to do a full restoration of the car. Parts are not a problem as I will importing the necessary from Japan and Australia. Appreciate the advise. Thanks.
  11. Hi, Need to get a test done for a Nissan Tiida before purchasing. Car is currenly located in Boralesgamuwa 1. Do i need to go to A*W or will another place would do? Need contact info if anybody has. 2. rough cost 3. What will they check and will they give a report on engine condition 4. Where to find the paint code of the car If these were answered previously, please share the links. Thank you
  12. Hello, Need Mitsubishi Lancer C12 Parts for a restoration project. Any help is greatly appreciated. Below are the parts needed. Inside (Car Colour - Nevada Sand) 1) Dash Board with Meter 2) Console Box 3) Door Arm rest (all four doors) 4) Winder handle (All four doors) 5) Door trims 6) Center mirror Outside 1) Front and Rear buffer 2) Side Mirrors (Both) 3) Nicole frame beading around the body 4) Nicole/plastic door beading (all four doors) 5) Two signal light strips just under the head lights (both side)
  13. Thanks Don. Big Help.
  14. Thanks machang noted.
  15. I know Mr Wijesinghe. But as far as I know Advance only does polishing and cleaning headlights. I want to get the brackets made from a very good Fibre guy or a plastic moulding person and need advice on removing the scratch mark from that lense. Please PM me your email so I could send you the other pics as well.
  16. Hello All, I need advice regarding restoring and repairing a used Japanese headlight. I am bringing down a headlight for an Allion 260 from Japan and there is a broken mount. Where can I get it repaired original as possible with the same mount color and where can I get possible scratches on the headlight surfaces sanded and buffed out. Please see the pics. Thanks
  17. ecs one (1) R!!!!
  18. Im talking about ##### fuel and engine additives. Any good?
  19. Hello All, Anyone currently using these additives? Is it any good or just a fluke to rip your money off? Value your comments! Thanks
  20. Hi Tharindra and Rukshan Yes went for a test drive today. The car was horribly underpowered. The car didn't even accelerate on the 2nd despite flooring the pedal. Don't know whether the engine is under compression. The car has been painted though and verified correctly so by rukshan as well. Just researched about it been so underpowered, and lot of forums mention the MAF, plugs, O2 sensor and fuel filter. Should I buy this car honestly? Is there anything better around? The owner is adamant the car is the best E30 around. Is it true? Anyways I was also considering offering him 950 k And also when I checked this particular green and another black one, both of them were missing the check light! value your comments thanks!
  21. Hi guys, I Am Planning to Buy an E30 316i very soon. I have come across two cars so far. But one bottle green BMW is up for sale in Kelaniya. This particular car has headlight wipers as well but do not work. The owner told me that he has done a lot of repairs on the car such as suspension and exhaust. The exhaust has been replaced from the manifold to the tip. The exterior is in superior condition. However the interior is not the best around. The door lock is giving problems and have to be repaired or replaced. The owner said there is a vibration on the steering at high speed and on long distance travel. However he said the tie rods, and all bushings have been replaced so I don't know what the problem would cost me or how to diagnose the problem. Do you think this model can be STOMP TESTED? Please if you guys can just look at the engine bay and the exterior of this vehicle and let me know whether it is a good vehicle to purchase. I know it is hard to tell without actually looking at the car. However value your opinion. Furthermore the price is steep and the owners asking price is 1 million. Just let me know what you guys think. Thanks a lot. Sorry guys could only upload the engine bay!
