Nimz77
Everything posted by Nimz77
  1. http://www.run-rite.com/industry/1515.html please let me know can we clean injectors using above device.?, is this true
  2. Nimz77 replied to Nimz77's topic in MAZDA
    please advise.with good place...
  3. Nimz77 replied to Nimz77's topic in MAZDA
    Thanks..for your support....
  4. Nimz77 replied to Nimz77's topic in MAZDA
    thanks....what about new mazda agents?i need good place...get fix..proper.way.. ;(
  5. Nimz77 replied to Nimz77's topic in MAZDA
    Still no..looking for good place...but now another problem...when we start car...i need to do acceleration 1500rpm or 2000rpm...to get idle...other wise engine get off...also when i on ac....same problem...idle will get down....500rpm...400rpm...some time engine get off... im assuming issue come from IAC or vacuum leaks....no idea......need to find better place...if you know good place ..please let me know...
  6. could you please let us know...place?
  7. Do u hve Ebay seller store name /link?
  8. Hi, You can get personal loan from bank...(but now interest rates are high).
  9. Thanks.....for support.... ...
  10. same problem in my car also...
  11. Nimz77 replied to Nimz77's topic in MAZDA
    Please let me know good place to check..
  12. Nimz77 replied to Nimz77's topic in MAZDA
    Can you send me contact number ...L*l Al*watta....how much they charge?
  13. Nimz77 replied to Nimz77's topic in MAZDA
    yes..he did adjusted screw.please advise good place to get check my car.
  14. Nimz77 replied to Nimz77's topic in MAZDA
    do you know any good place...i can get check my car?
  15. could you please explain about Fuelly Tip Replace Your PCV Valve Especially in older cars, your positive crankcase ventilation valve will get dirty and gummed up, which can cause cause excessive fuel usage. Fortunately, the pcv valve is easy to replace and very cheap to buy for almost any car. You can test your old one by taking it off, cleaning it out with some carburetor cleaner, and blowing (or sucking, depending on the end.) If it makes a nice solid seal, then it's still good and can be reused. Can you explain about mazda PCV Valve ?
  16. sorry,,,what i mention here as a experts mean ...who can explain ....advise....because some of are trying make this topic as a joke...
  17. Nimz77 replied to Nimz77's topic in MAZDA
    could you please let me know good place for check my mazda bg5s.please....
  18. Nimz77 replied to Nimz77's topic in MAZDA
    woow..thanks....lot...do you know any place i can get diagnosis? my is car is old...1992 yom efi..dohc..efi i did scan at macrotech and nalaka both but no errors.. just to tell you...six month ago i went to nalaka(union place) to tuneup engine...on that time they have remove throttle body and some did cleaning....(Before tuneup no starting issue).may be that's the reason for above problem...
  19. Thanks....mazda bg 1992.....i will try ...
  20. Nimz77 replied to Nimz77's topic in MAZDA
    im new to cars...could you please explain more about this...can continue car with above problem...or sooner... do i need to replace it??
  21. sorry im new to cars...im asking.....do we need check RPM less 3000k???or how to control car.......speed...for better...fuel...hope experts Will comment...
  22. Nimz77 posted a topic in MAZDA
    my problem is .. *.When we start car in the morning ...on first ignition car will start. *but after when we travel.(5k,,,10km or more) and after we stop car.(park)..(after 30min).but when i start again car wont start on first ignition,need to try two or three time then car will start. *.but when i try car start(ignition) with little acceleration car will start . Mazda bg car ..1500cc ,DOHC...yom 1992... please advise where do i need to check.? fuel pressure is ok.. plugs is ok. O2 sensor is ok ECU is ok.
