anuradhaplanter
Everything posted by anuradhaplanter
  1. thats according the way u drive cos if u sqeese 3/4 of the padel then only the secondary part opens then the car drinks,if not if u drive with mild padel then car does the normal milage its all about controlling the accelarator
  2. found original tail lights but its not in good condition so im thinking twice .today shit thing happend i wanted to change the oil plug when im tightning it, the housing splited fortunatly i m having a spare one tomorrow i have to replace it
  3. guys i did a recent modification to the carb i made the secondary jet to open manually(originaly its vaacume operated) and remowed the chocke plate now when u sqeese the throttle its pickups like a turbo and rpm goes above 8000(meter shows only 8000)
  4. check the tyers if its new no problem same thing happend to me when i checked the tyere had a buble cant be the prop shaft if it has a problem when u pickup it gives a clunk sound
  5. i dont think its engine mounts b cos 70kmph u r on some what high rpm i think its u r front tyers , carb low on petrol or dif bearings
  6. and guys when ur selecting a bosch high performance ignition coil be careful there are enough and more counterfit ones the original german coil is blue color and the top is red the aluminium colur is called the prince of darkness cos its manufactured by lucas and branded as bosch http://img194.imageshack.us/img194/9459/p7030086.jpg
  7. the rear view http://img189.imageshack.us/img189/479/p7040088.jpg
  8. i was reffering to my dads car it was a two door one we sold it i am searching for a 2 door car i want to fix the 4g32 engine and to modify it like the rally type of 1974
  9. yes guys i fixed that temperaraly i have the original lights have to find good lences after that im fitting the original lights
  10. no this is a flat light by friend hit me in the rear when we were racing so the buffers tail lights all gone
  11. Thanks man i wanted to do complete over houl as there were some oil leaks but after removing the engine the bore was good so i replaced the rings and fitted replasing the ovehoul packing set now the engine good as new .the front i wanted look better so i fabricated a new bumper with a scoop .also the original bumpers were corroded is the bumpers and tail lights available in sri lanka cos my tail lights also got damaged now i have fitted sky line tail lights.and i replaced the caburater with 4g32 aisan cos the original solex was a iternal headache .the chaging alsa was bad cos after fitting the a/c (this didnt had original a/c)i replaced the alternater with a new which has a inbuilt regulater
  12. yes i have to try from ausi http://img706.imageshack.us/img706/3771/61672568.jpg this is the link of philipine one
  13. one manufold was in philipnes auther one is in australiya. your right i have a spare engine head i must fabricate a manufold using that .is there a posibilty of modifing the carb to open both chambers together and to make more power
  14. may b but its look like a upali fiat. i also thought about making a manufold allready i m doing a exhuost manufold tricky part is the main water line runs trough the intake manufold and the thermostat also located in this thats why im sceptical about this ,i found a dual carb manufold in e bay but no shipping available here what are ur idias of fitting a turbo to this engine 4g33
  15. our one was L light
  16. guys if any body seen a 2 door 1973 lancer cos we had a 10sri my uncle brought it from japan we sold it for a immergency and i still regret that decision i think its a gsr
  17. hi davi , well done man love to c a new project by u
  18. its silicon never gets hard like plastic so it wont leak and its very flexible
  19. i agree its very easy to repear
  20. what i aded 1.full bosch high performance ignition system. 2.silicon vacume and fuel lines. http://img215.images...6/p6270087z.jpg 3.open high flow air cleaner with oil cach can. 4.gauges(R.P.M,oil pressure,ampere,water temp,volt,) 5 a/c 6 2win carb 7 205/60-13 tyres 8 alloy wheels 9 two elecrtic fans for emergency cooling 10 modified exhoust 11 kenwood 4 way stereio with 2 8" woofers what im hoping to add .power stearing original racing alloe wheels 4.recaro seats
  21. may be i m mad but for my knowledge one of the best cars of all time its a 1973 model and look at the features 1.1437cc SOHC engine 2.five forwerd 3.front disks with servo asisted brakes 4. top speed above 200kmph(if u upgrde it to twin carb) 5.rear wheel drive engine http://img207.images...01/p6230097.jpg
  22. installed silicon vacume and fuel lines as the normal lines gave me trouble images below http://img215.imageshack.us/img215/8546/p6270087z.jpg
  23. this link doesnt work try a new link
  24. http://imageshack.us/photo/my-images/441/p6230094.jpg/ this is my beauty
