Hid Xenon Lights
Thanks and posted this out of the panic after ending up with too many sellers who doesn't ship to SL. However, the cheapest lot, the HK and China sellers do not ship to SL due to unethical behaviours of SL based buyers. Went to customs only ones and all other instances, goods delivered to doorstep including a set of (04) lock handles for VW Golf which I got surprised shhh, I'll tell ya, if the box looks plain old and useless, they won't detain it and charge you sky high.
Vw Golf Brake System
Hope Supra's advise will not be in vain, if I was you, I'd obtain help from the friend based on his competency. End of the day, you'll lose the quality of the vehicle and friendship both, if anything goes wrong, trust me I've burnt my finger in this, so to speak.
Micro Mpv Junior 111
bummer! now only noticed the hoard of newbies commenting positively and having second thoughts to take back the statement I made whole heartedly
and first thing reminds me of this van is the locally fitted hang on type front Air conditioner, now compare that to a F/F Dual Air Conditioner
Hid Xenon Lights
not quite sure the exact color temp but price isn't largely vary depend on the color temp do they? bit lazy to do R&D with LEDs and waiting for the package to deliver and fix it is far more easy. Must run another search for LEDs in the bay again. Counting fingers till Saturday to swap the HID to low beam, simply I don't wanna ruin the bosch unit I've brought down.
Great, and if your guy couldn't do at much as you have done, no two words, you should change the fella one small tip in bleeding brake systems, use a plastic/rubber tube which can be attached to the bleeding nipple along with an emptry brake oil container. Helps a handy, cleaner job and minimizes risks of brake oil contaminating with paint or chassis/underbody.
Toyota Passo Key Problem
dodgy key barrel for sure and it activates immobiliser function "assuming" it's a wrong key trying to break open. Correct solution would be new barrel with a new key programmed by agents (if they cannot repair the barrel) but this will cost an arm and leg, suggest you take the path of nano31s friend took. Cannot guarantee the immobilizer function will work afterwords if they bypass certain circuit
way to go with Euros, handling repairs / maintenance by yourself than giving it to a makabass who would destroy the thing. What have you done BTW?
Hid Xenon Lights
In local context the chinese cheap ones quoted somewhere around 12 to 15k, same can be brought down through bay of E for about 4k including shipping
Hid Xenon Lights
Thanks for suggestions, Yeah, can change the HIDs into low beam any time, after reading about how HID ends its life, I think it's better to use for lows. Might do the swap in the weekend. How about the power of LED bulbs? do they as good as HIDs ? I'd still go for bluish for bumper lights to have uniform 'look' on the lights, or else different lights appear in different colors which doesn't 'look' nice. How about 4500k ?
Express-Way Updates
Rarely push it past 80 ? I reckon it's the time for an engine re-build and a diesel pump repair We had a townace CR26 with 1C engine and I've touched 120 manier times, usually on Moratuwa - Panadura stretch and passing 80 was just nothing in 5th, still remember how the 5th pulled the van above 60. Check the diesel pump settings for fuel flow and throttle openning limit. In ours I've changed all from standard settings, with those seals Make sure the van got some wide tires preferebly with alloys and some weight in the back, such as a set of after market seats at least Not a must but this will help in negotiating those bends in the highway in higher speeds
Express-Way Updates
I suggest you read and comprehend my post again. Ever missed the part high end cars in my post? Dude, not every city running econobox suits highway driving. Even if it does, its not optimized for highway driving. Most Japanese cars popular in SL aren't meant and build for long distances, however, the bashed lot, such as crowns, primeras will prove themselves to be as economical as an AE100 on highway driving. For your record, an average 406 does well above 15 on highway driving as they're designed and optimized for that. Dont be silly and judge euro owners in the context of penny wise pound foolish econobox owners where only objective of owning a vehicle is to sell quickly with a profit. Won't waste time anymore wrestle a pig
Hid Xenon Lights
4300 is warmer and yellowish compared to 6000k. The more the k value candle power and bluish increases and above 10k is purple sort of.
Hid Xenon Lights
Thanks, I have already settled for a slim kit from us. Yeah, found lot of auctions only For bulbs and some were only for a single bulb and ballast.
Hand Brake (Parking Brake)
one important factor to consider, that is this adjusters are made in such a way that it automatically adjusts when parking brake applies. So, the shoe will be close to the drum and hence has an impact on brake padeal travel distance, brake / response time and distance. So, this is not only for the parking brake. Try searching in breaking yards in Panchikawatta as even Lancer box model ones can be interchanged. I think sourcing the original one would be a better bet coz you will have to manually adjust the shoe time to time if you don't have a working auto adjusting mechanism.
Its not same for every car. Attached picture is not off from a car AFAIK, looks a van or a J44 rear drum to me. Should be able to buy (I could source the same for my ex 406 about 4 years back) or re-build the worst case as Don said.
Hid Xenon Lights
Could find a US based seller but you know, they are not among the first few pages when you sort based on the purchase price + shipping Cheapest options don't ship anymore to SL I already have high beams running on HID (in 406, there are 04 lights, 02 for low beam and 02 for high, all H7) with 6500k and gives a superb visibility in night only issue is takes few seconds to light at full blast. This time I'm looking for pair of H1s with 8000k for the driving lamps on the front bumper. They gives better visibility to identify ripples and potholes in SL roads and I can't take a chance with extra lowered Executive suspension. Yeah, that could be the reason and worried this will influence other sellers and we find us in a situation where nothing to be purchased off from bay of E. Initially thought something to do with global politics and economic restrictions It's only high beams and I do dip the beam strictly (whether with HID or not) and with HIDs I'm extra cautious not to blind oncoming drivers. This doesn't apply for some idiots whos driving position is 3-4 feet above ground and doesn't know what the low beam is. You know the population I'm referring to I guess
Express-Way Updates
Precisely the demand for high end cars and generally for Euros will increase with more highways coming in. People will start looking at safety ratings rather than km/l figure when buying a vehicle.
Hid Xenon Lights
thought to revive this thread as I'm looking for a HID conversion kit in the bay of e and almost all matching conversion kits I found the sellers will not ship to Sri Lanka. Has anyone noticed this? any particular reason such as return/deport by customs by any chance?
Can Super Diesel Be Used Wth Any Diesel Car?
Must be one isolated instance
best would be to ask him to re-confirm there's no air bubbles in the system and ask whether it's require to bleed close to the pump as I've seen this is required in certain tandem type pumps where dual circuits are being operated.
super diesel would be cleaner than the normal and is the only difference to the best of my knowledge. less smoke I don't know but super diesel would be smooth on the feed circuit, filters, pump and injectors they say. Run for sometime and find the difference in smoke and pick-up/power.
Did he bleed from all 4 points and also from the master pump itself? since it's a complete flush of fluids a thorough bleeding is required unless you used a bleeding machine. Only suspicion is air inside the system as you didn't touch the disks.
does the pedal comes up when you pedal few times at raw? then when you keep pressing it, do you feel it goes further slowly towards the firewall/floor? If you answered Yes to both questions, there are still some air bubbles inside. Sounds like you have gone to non-golf/Euro expert, no offense but that's the first step of ruining that beauty I feel.
Cr51 4Wd Remove
Tappet covers (room between the tapet cover and the hood/bonnet is less in car, so valve cover is more of flat than the van engine), t-belt covers (van engine has provision for belt driven fan mountings where as there's no mechanical fan on a car engine) and air intake lines are different. Car engine will have an additional mounting point on the t-belt housing end than the ones fits the cross-member.
