Hey,
My car sputters/misfires at idle and low rpm(throttle barely pressed). The problem first came up(might be best if I start from the beginning) on a thursday night. Car ran fine in the morning, problematic in the evening. If I accelerate, the engine loses revs(like it's about to stall). Once it finally gets going, it'll hold that speed with no issues. Couple of days later, can't accelerate above 30kmph. Stalls if I let it idle for over 10 seconds. And then finally, refused to start up at all.
Problem diagnosed to a bad distributor. Coil was replaced(old one was burnt) and car started up fine and ran fine.... for around 50km. Sputtering and stalling started again. Took the car to a different garage. Injectors cleaned(tune-up done 4 months ago though they were dirty again), throttle body cleaned, manifold cleaned and new spark plugs installed. Distributor timing done and car accelerates fine(better than ever) and throttle response improved. It still sputters at idle and low throttle. Loves to rev though.
The mechanic says it's still the distributor, that the new coil's resistance doesn't match the ignitor (googling this gave me no answers). So it would be best if I get a new distributor installed.
What I want clarified is, is this true(coil resistance thing)? Will I have to get a complete distributor put in or just a new ignitor to go with the new coil(only one shop in delkanda had it)?
Also air filter is clogged up(from the inside, car has been backfiring). Anyone know where I can get a cone airfilter? Checked panadura(one shop called a few more shops in panchikawatta) and kaduwela. No luck . EBay shipping is $50+ . Car pulls even harder without airfilter.
Car is a 1998 Honda Integra.
Thanks in advance and sorry for the long post!
