Everything posted by cefiroA33
hi guys, Just returned from the mechanic. We brought the car home from there as the issue has never been come up when it was there. However after we brought it to my office, I observed that when it is pedaled gradually (say from initial RPM to 3000, gradually pedaling so that RPM also raises gradually), RPM indicator shakes while it is raising. and during certain intervals it suddenly drops (say about 1000 RPM drop). I have been repeating the same thing over and over 3 or 4 times and the RPM started dropping continuously until it no longer raise and the engine stopped. Now my brother is getting ready to take the car to M*z*na. I hope it wont give trouble while going in the heavy traffic in Nugegoda, kohuwala area. Regards,
Rumesh I tried messaging you but couldn't get through. Is there a good place we can take the car to have a look at all what u have said. Cos I don't think the current mechanic has a clue of what's going on.
Hi guys, thanks for your responses. Rumesh thank you again for extending your helping hand. Car was not subjected to floods rumesh. I shall PM you some details. Highly appreciate if you can reply.
Guys, I will be taking over this thread to discuss an issue with my brothers Mazda BJ5W triptronic VVTi engine. Few weeks back he had experienced a sudden engine shut down while he was driving (from panadura to Townhall). few seconds after when he cranked the engine it had started again and had been running smoothly for few days. Then again about two weeks back, car suddenly stopped near Mt lavinia area after a drop in the RPM (no matter how hard you accelerate RPM doesnt go beyond 1500-2000 or so) and the car stopped with a vibration. Then again after few minutes it became normal. But this time we took it to a mechanic but the issue was not there at the time it was taken to the mechanic. Mechanic also had a test drive, did a scan but nothing came up. However mechanic observed that there's a oil leak from the engine and he assumed it might be due this oil leak that the crank sensor has been malfunctioning. So we replaced the crank oil seal and tapered covers, also fix a new crank sensor and started running again. After few days running (two days to be precise) the issue came again. Same way the car stopped after dropping in the RPM and vibration. This time since I was also there at the car I told my brother not to take the key out but keep cranking the engine and if the engine start again keep running with the problem until i get a mechanic. So we were successful and i managed to get a mechanic with a scanner while the issue was there and after the scan attached error report was produced. https://www.flickr.com/photos/143772339@N08/27332286162/in/dateposted-public/ https://www.flickr.com/photos/143772339@N08/27332286262/in/dateposted-public/ Then again the CAM sensor was replaced but the issue was still there. Later the Air flow sensor was replaced (After replacing the old CAM Sensor). However non of the above has been successful. Can the experts here assist me to overcome this issue as we are clueless of what else to do. Regards,
Hi guys!! Sorry for delay in responding. The issue was sorted and as rumesh correctly said it was the water pump that created the issue. Due to the use of water instead of the coolant, water pump has been damaged severely. once it was replaced with a new pump heating issue disappeared. Purchase the water pump from Pi_ne__r motors panchikawatta and they were surprised that issue was identified correctly soo soon. speacial thanks to Rumesh88 for this. Regards,
Hi guys I checked with a mechanic and he said the thermostat valve has been removed. Also I am using coolant instead of water. Heat gauge goes well above the half way mark but as soon as the AC is turned off it drops to the half. Anyways I sent the radiator to be cleaned to check whether it is due to any block in the radiator.
Hi guys. Wishing everyone a prosperous and peaceful new year. I have a issue in my second car Nissan Bluebird SU14 1999 diesel model. I have noticed that heat goes up after running 7 or 8 km with AC on. Going in to more details during the mornings and evenings generally the AC indicator is in 1 position heat never goes up. But during the noon when 1 is not enough due to heavy heat in the atmosphere, and the AC is on 2 vehicle heat going up within 7-8 km run. This distance declines with the AC position going further up. I have checked applying some night speed water jet to the condenser to clean it but the heat still goes up. Can anyone help me on this regard? Thanks.
Engine Miss & Petrol Smell In Cold Start
cefiroA33 replied to LancerL's question in Mechanical problems
Thanks romesh for your advice. In face i am not sure about the TPS in my car. Is there any good work shop to repair these sort of issues? cos I dont think my current mechanic would be capable of doing such repairs. Regards, -
Thanks Charlie for your reply. Well this did not happen on the E01. Drive on the E01 was smooth. Actually this happened in Hambanthota where the roads are very similar to E01 and the drive is exactly like on the E01. I did not change the throttle position sensor recently as well. can a scan recognise this error? -
Hi guys. I have a small issue with respect to the engine of my Nissan Cefiro A33 petrol 2L V6 which I thought I would share with you for your expert advice. Recently I carried out a major repair to my engine with repairing all the oil leaks replacing oil seals and o rings etc. Also I replaced 3 out of 6 ignition coil plugs with Nissan genuine ones (But purchased from Pioneer motors) and also I did a complete tune up of the engine including throttle body cleaning etc. After that I went on a trip to Yala and after say 175 miles of travelling I experienced there is a sudden drop in the RPM when it reaches the 2000 mark and it comes with a misfire in engine as well ( I felt the vibration in the car when engine misfire). However this issue only came when the RPM was increasing gradually and when it was suddenly raised to 2000 - 3000 no such thing occurs. After returning I have been running for almost 1000 kms now but so far nothing has improved but i have noticed that even if the vehicle is in parked mode and accelerated gradually till the rpm reaches 2000 the sudden drop in the RPM is experienced between 1500 - 2000 range. You guys being the experts would be able to identify the issue easily and please enlighten me. Thanks and regards -
Vibration When The Car Is Stopped In Traffic
cefiroA33 replied to wotson's question in Mechanical problems
Hi guys, Sorry for reactivating this thread. I like to share a recent experience I had with my Nissan Cefiro A33 to get your expert comments. Recently I took the car to the agents due to a fault in gear shifting and did a scan. Gear shifting issue was sorted and during that scan it was indicated that a fault with the ignition coils. What the agents told me is to replace the coils with a massive estimate. Then I took the vehicle to a one technician who was introduced to me through Autolanka and after some scanning he confirmed that all coils are in good condition and so does the plugs. What I was told is that there is a oil leak from the crank oil sealer (in front) and that disturb the crank sensor and connector thus generating an error message. Hence he asked me to replace the crank oil seal and clean the crank sensor to redo a scan and get rid of the error message. I also have notice the vibration that has been discussed in this thread in my car. It is significant if the gear is in D and haulted with breaks (like in a traffic). Once the gear shifted to N the Vibration reduces. Further this vibration is very much high when the AC is on. and 90% vanishes when the AC is off. Recently I noticed that after a very significant vibration AC automatically off and only the fan was running. but after a while it started running again. What I want to know from you guys is whether the error mussage I got at the scan I did at the agents is directly linked with this issue or is it that the error only comes from the crank oil seal leak and this is a seperate issue. Thanks for your valuable time. -
guys, today i took my car to A*W and after a scan they diagnosis the issue as transmission output sensor failure. So the sensor is being replaced. However during the scan they also identified an issue with the ignition coils. What I was told is that six coils needs to be replaced. However because of the massive estimate I didnt want to do it at this stage. So can anyone reccommend me a good place to have a look at my engine and ignition coils at a reasonable price. Regards
- 6 replies
- mechanical
- gearbox
(and 2 more)
Thanks guys for your valuable comments. I have booked an appointment at A*W on tuesday for a scan. if it doesnt indicate any error hoping to take the car to Nilwala motors for an inspection. will keep you posted
- 6 replies
- mechanical
- gearbox
(and 2 more)
Thanks davyy. Another thing i realised is that this issue always came when I was climbing up the hill. No issue when travelling in the flat terrain
- 6 replies
- mechanical
- gearbox
(and 2 more)
Hi there members, After a long time and hope you guys are keeping well. I had a slight issue with my Nissan Cefiro A33 yesterday and I hope you guys can help me sort it out. Yesterday I was travelling to Kandy from Colombo when suddenly I felt that the gears are not shifting smoothly. This happend when I was passing Pasyala area after starting the journey from Moratuwa. For a certain period of time gears were not shifting eventhough the RPM raised. Then I stopped at a nearby garage and since it wasn't open I had to wait for like 20 minutes until the mechanics come and the car engine had been stopped. When the mechanics start the test drive there wasnt any issue of shifting gears and all were ok. So again I started with the journey and continued until Kegalle when the gear shifting again started failing. Then again I stopped the car for a while and after few minutes rest the problem sorted. I parked the car at a friends house in peradeniya and came back to colombo by bus. Guys My periodic service is due and also I have run for like 25,000 km from my last ATF change. Can you guys advice me on this issue. Thanks and best regards,
- 6 replies
- mechanical
- gearbox
(and 2 more)
Hi all, Don, Well to be specific with my fault what the key person there told me was that a plate has been replaced earlier with an incorrect one where the correct one should have 8 diodes but this one only had 6 diodes plus two lines were given direct supply. Thats what I understood. Regulator has also been faulty. This job cost me 22.5K. I never checked for any other places and add to this my last time alternator service only charged 2K which I presume only removing and refixing. and it took only one day for the total job. Davy thanks for your concern and this is my first job done at Pala and there seems to know what they are doing. I was looking for a reliable mechanic in Colombo area so that I can put my car to the repairs in the morning and pick it up after work. Pala seems a good option.
Hi Guys, Took the car to Pala and it seemed the Alternator had been modified at some point without I am being aware. Plus the faulty regulator was replaced as well. in the meantime after all are fixed and the engine was running to test the battery voltage, it was observed that one fan was not working as well. But my car never had a heating issue although it seemed to be running from a single fan. However it was replaced as well. Did couple of night trips thereafter and so far no issue. We shall wait and see. Thanks guys for your valuable advice. Looking forward for them in future as well. Thanks alot.
Guys, Thanks for your replies. Yes I am hoping to take the car to Pala tommorow morning. Would replacing of the Alternator cost me heaps? I am sorry guys this is the fist time the alternator is giving me problems so I am not sure of the cost associated with it. Thanks.
Hi Guys, Couldn't log on to this forum for a long time owing to busy work schedule and ofcourse the car was running smooth. But recently I had this issue with the electrical system for which I fix 100%. To begin with my Nissan Cefiro A33 starts in the morning without any problem and during the day time it runs smoothly with AC and radio on. But during night time, when the lights are on, and while its running, I could observe that the dashboard illumination dims time to time and at the time it dim, the radio and the AC is also switching off. head lamps also dims time to time. I showed the problem to few mechanics and they ran some tests for which following actions were taken time to time. 1. One guy told me that it must be something wrong with the alternator and asked me to get it serviced which I did and the problem vanished for few days but again it appeared. 2. Then his view was that the battery might be defective which I couldnt agree because Its only been one and half years I replaced the battery from A*W 3. Then I took the car to A*W and they had a good look at it and their view was that its not the battery but the defective alternator but replacing the alternator with a second hand one would cost me something like 45K. Can someone please advice me if this issue could be addressed with less cost. Are there any reliable mechanics that would assist me in this regard. Otherwise my only option is turn in to A*W for their reliable but costly service. Regards
Nissan Sunny Fb14 Auto Gear Shifting Problem And Fuel Efficiency
cefiroA33 replied to HarshaAG's question in Mechanical problems
yep the same nightmare I had quite sometime back. Unfortunately I wasnt a member of Autolanka at that time and ended up replacing my gearbox with a reconditioned one. beleive me you could just try once with repairing your gearbox with any of the above mentioned mechanics its still be worth than replacing the gearbox with a reconditioned one, specially considering the cost difference of the two options. I still regret not being a member at that time. -
Lols its Mr. Pa_nt. Anyways I had only one experience there and its a rear bumper damage and i couldn't find any fault on my one. But If there are negative aspects you should look at them first.
Isn't Mr. Pain a good place to do collision repairs?
http://www.colombopage.com/archive_13B/Dec17_1387295043JV.php The above link might explain why it was cancelled suddenly. But I too think later on they will reschedule it.
To be honest with you guys this particular radiator thing happened during my last service very recently (Even after my steering rack repair Komi) and all was fine until they told me this. I was pretty happy about my car getting the attention of the agents but this made me really frustrated and the reason for this post is same. Although I am a newbie I have seen the parts that comes with a new radiator and this line is no way even near the radiator and it made me wonder for a second whether all this time I was taken for a ride, Thanks for bringing that up.
Talk to my hand watchi . but thanks anyways.
