PathumLK:::::::
917 profile views
PathumLK:::::::'s Achievements
  1. I need to get clean my petrol car catalytic converter system ( Emission System). any place that i could done this thing near kandy? ( colombo also ok to me ).
  2. PathumLK:::::::
    Auto gear
    I have a toyota vios 2003 model car. Recently i had a small auto gear oil leak and i went to repair it ( axel /gear box seal worn out ). So the technician took out the gear oil before doing the repair job. After the job done, he put the oil back but unfortunately he drop some amount of oil to the ground though engine bay. Then he added Texamatic® 1888 oil in to the auto gear box to get the auto gear oil in to the the level. The running is smooth and no any error occurred . The problem is the dipstick mention to add Toyota T-IV oil to the box. The oil is new and the technician add around 500 ml Texamatic to the box. Is this a dangerous thing to my auto gear box ? Should i be worried about this? ?
  3. I have no idea about your problem but i also faced similar problem with my toyota car. When i brought ( second hand ) it, i noticed that there is an abnormal heat after parked. but the heat indicator did not light up while driving. after few months later when i was on my way to n- eliya, RED heat indicator lighted up. I changed coolent , radiator. but the problem was there. later i discovered that there was a small gasket leak in the engine. While driving on flat areas it was not a issue to the car. but when it get load, it could not bear the heat. the best thing is compare it with another Wagon R . Also start the car and open the radiator cap and check if it gives any bubbles. modern vehicles does not come with heat meters. that is a problem to check this types of problems .. i personally do not like bulb indicators .
  4. Do you guys know a best place for car audio in kandy . Reasonable price with professional work in audio wiring and installations . tnx
  5. Do you guys know a good place to buy vehicle electrical parts like wires, Fuses, switches , clips and sockets in Colombo specially in borella /panchikawattha / rajagiriya or nugegoda areas. The reason why i ask this is im from kandy and i need to buy some small car electric items which are not available in kandy. please help me .
  6. I recently notice that a White Noise come out from car speakers. The audio system works perfectly before. Any idea about it ? Do you know a place to correct this problem in KANDY Noise sample from Youtube
  7. I have bad experience with car electrical repair never go to nih@l electrics kandy. road side workplace around suduhampola fire brigade ( few meters ahead to kandy ). He does not know anything about how electrics works. he wrap blown fuse with wires.never finds actual reason for the cause. always finding easy ways and dangerous ways to overcome the problem. his chargers are higher too
  8. try c & s ventursa in peradeniya. polgahamula junction. they have pretty knowledge about the service and repairs . reasonable price for my repairs
  9. Thank you very much for the information. It is not an advance system . it do only lock/unlock and alarm. It cost me around 4500 i guess in that time. I will try the negative battery terminal step and see if its work. otherwise i will take the car to the same place where it was installed. thank for your information again.
  10. yes sir. I have after market door lock and alarm system. i install it around 2015 i guess.
  11. I have toyota vios 2003 car Normally when a door open, signal lights starts blink for several times. This system works fine until today morning. I did not do any repair or anything. Now when doors open dashboard "door open" light indicate but the signal lights blinking does not happening. Car works fine ( normal start/ radio/ setup/headlights) What could be the problem and where should i check. p/s - when hazard switch on, both signal lights blinks. also lights works with signal switch too
