tcfern1
Everything posted by tcfern1
  1. Yes.dont go for vezel.most people bought vezel due to the trend which was there in 2014/2015 But now they are facing the reality due to poor resale value and also the said technical issues Go for toyota and you will be in safe hands
  2. According to reliable information tax on hybrid below 1500cc will also come down.the exact percentage is not known.but definitely it will come down
  3. pls check the steering rack bush. there is a steering rack issue in passo. its also a possible reason for vibration
  4. As far as iknow most of the service stations except the recognized ones like automiraj......... Use burnt engine oil to spray undercarriage along with kerosine. When billing they mention it as penitration oil. That is how they make profits
  5. Go to pitstop
  6. Finally got it checked at TL and confirmed that the white vapor is water vapor since the engine has no issue Thanks everyone who shared advice
  7. Oil burn smell should come from engine bay or from the exsaut Pls advice how to identify?
  8. Is there any way how to identify it is water vapor?
  9. The engine oil is toyota o-20 Change it at 5000km
  10. Is it possible to get a leaky valve guide since the milage is just 16k km(16000km)
  11. Thanks for your advice rumesh88
  12. Recently i have noticed that white smoke comes out from exhaust when accelerated in my toyota axio hybrid car. Current milage is 16000km Seek the advice from experts Thanks
  13. So is not there any solution to this?
  14. My axio hybrid engine rattle for few seconds at cold start up occasionally Seek expert advice regarding the issue
  15. toyota lanka also uses water to clean enginne bay of hybrid cars.usually they clean the outer area inside engine bay with low pressure water. nothing to worry about using water in that way.the chemical is used to clean the centre area of engine bay
  16. No 313 kotte rd, jubili post nugegoda
  17. Go to magic auto touch up at jubili post nugegoda
  18. This rattle is occasional not on every cold start up if the situation is supposed to be normal Otherwise not
  19. This is a common issue in hybrids Nothing to worry
  20. cvt gear boxes cannot be repaired like normal gear boxes
  21. They are going to introduce new excise duty
  22. Customs has today issued new fob values
  23. I believe the hybrid taxes will remain unchanged since the goverment has revised fob values
