maithri
Everything posted by maithri
  1. Hi The coolant temp on a car once warmed up should be around the half way mark in order for the engine to perform efficiently-I.E. achive the best combustion-Most cars have a thermostat-a vale controlling the coolant flow from the engine to the radiator for cooling-this will keep the hot coolant in the engine till it arrives at the optimum temperature then opens and allows the coolant to circulate through the radiator where the flow of air through it's fins cools the liquid on its way back to the engine. When the air flow is poor as when you are in stationary traffic the cooling fan switched on by a temperature controlled switch draws air through the radiator to cool the liquid. Your system appear to be working ok. The rust floating in the coolant(water) is a result of lack of corrosion inhibitor in the coolant-This is mostly present in anti freeze concentrate used in colder climes like where I am in (UK). This is good practice even in SL purely for its corrosion inhibiting abilities, keeping your radiator and your engine clean. Flush and refill the system with Distilled water and at least 1 liter of anti freeze to keep contamination at a minimum.
  2. Hi, Throttle body getting contaminated is a common occurence in many cars. Sometimes this can be alliviated by using a different brand/grade/or type of oil. First check if you have a engine breather attached to the air intake. If so clean it throughly and ensure any breather caps etc is working correctly-replace if faulty. Clean the throttle body with a good air intake cleaner-open the throttle and clean the edge of the butterfly-do not scrape as this will cause further prfoblems-soft cloth is best. In my own car a Golf GTI I had this problem often and even being an experienced technician could not find a fault-I found the cure by accident when I used a different brand of oil at the next service-and never had the problem again-I still check the throttle body at every service and have little contamination or none at all-So try!
  3. I work a lot on diesel cars and common rail diesels are pretty common here in the uk. I dont see the common rails being any less smokier than traditional diesels, however the peugeot HDI engines which use an additional cleaning process on the exhaust have very low smoke levels. I tested a 3 year old Audi a4TDIPD today and it barely passed the smoke test required for the annual MOT test. Turbo diesels smoke more than the non turbo vesrions during hard accleration. The best way to save money and stop un wanted smoke-which incidentally is mostly un burnt diesel is to maintain the system properly with regular fuel and air filter changes as well as the occational use of a fuel treatment(additives).
  4. Hi,Mate Tyres do not have to be the same size or pattern front and back-some very high end cars are desinged with different tyres front and back! Most cars have the same tyres front and back for cost reasons-but look at a F1 car-front tyres are thinner than the back ones- Jaguar xk models have different sizes and patterns on the same brand(pirelli). How ever before deciding to change the size of your tyre ask why-If it is handling the lower the profile the better they are-if it is comfort the lower profiles-i.e 45 or lower will give a harsher ride and leave a lot of damage on your wheels(rims) from the pot holed roads of Sri Lanka. Make sure you fit the narrower tyres to the front to avoid oversteer.Best advice I can give you if your car came with 215/45r17 s keep them adthe alternatives will not be that good-if it is a 4 WD then DO NOT FIT DIFFERENT SIZE TYRES TO ANY AXEL AS YOU MAY SERIOUSLY DAMAGE THE TRANSMISSION.
  5. Hi Guys & Girls, The freelander with the K series engine will suffer from the same problems that all cars fitted with the K series engine suffer. This I am now aware is as aresult of the low quantity of coolant circulating around the water jackets-so the engine struggles to cool effectively even in the colder UK climate. All of us who repair these heaps of s**t in the uk will not offer warranties on head gaskets as we cannot cure the faults on a poorly designed unit. Buy a diesel that has a much more reliable engine.
  6. maithri replied to madmax's topic in The Lounge
    Try the JHU they dont sell permits but give them to you if you give them money!
  7. Hi all, It's my first post here. I am a mechanic (Technician in modern uk speak!) and a garage owner in the uk. I have a solution if I may offer it to prevent your cooling system getting contaminated and clogged. Drain and flush the system-re fill using a mix of top quality Antifreeze (Coolant concentrate as it may be called now) and Distilled water-Use at least 25% anti freeze to water and top up if needed with the same mix whenever possible. This will prevent the Aluminium in the engine and the radiator forming a powdery sulphate that eventually leads to disaster. If you remove the thermostat which is really not needed in Sri Lanka unless you live in the colder mountains ensutre that circulation is not affected as most modern thermostats are dual purpose and close as well as open circulation to different areas of the engine.
