Ted
Everything posted by Ted
  1. Hi, These days i am going to buy one. Have you bought this type of car? If so may i know your experience on it?
  2. Yeah um gona do it.. early morning i went to drop my wife to office.. suddenly abs and break warning cleared yet check engine exists still. we will see. thnx.
  3. Removed and kept for abt 10 mins and reconnected. no change.
  4. Hi all, I have a premio 260. today suddenly i saw check engine , abs and parking break warning lights on in my dash board. Car is hardly used these days. however today i kept my car around 2 hours at a service center to repaint my front bumper. Issue was noticed after i left from the service center. Has anyone experienced such a situation? Thanks.
  5. Hi all, I have a toyota premio 260 and today suddnely, ABS, Handbreak and Check engine bulbs began to blink. Whenever I start the car the 3 alarm bulbs are iluminated. Any comments? I hardly used tge vehicle these days. Also today morning I handedover the car to repaint the front bumper.
  6. Ted replied to Ted's topic in Mechanical problems
    the belt is ac compressor belt V - ribbed
  7. Dear all, 1) toyota genuine compressor belt for toyota premio 260 is 10500. 2) I bought so called toyota genuine belt of the same from panchikawatta but mede in indonasia at cost 5500. 3) Also later i got to know that a thaiwan or singapre one is available for 2000 or 1700. Are 2) and 3) same ? If so have i wasted 3500?????
  8. Hi smith, I would like to know wht happnd to ur issue.. since same issue seems to have in my premio 260 as well. When ac is on i feel an unnecessary vibration which is not big but felt well. Also my engine did stop when ac is on and in idle state. This had happned for the third time.. didn't go to scan yet. Thought of going tmrw.. my ac fan belt has tiny cracks and it had been tighten more than normal.. i dunno wht the reason is..
  9. Hi wasa, Wht happnd to ur car? Same issue is in mine as well. Did u visit dhammika? Is he okay on doing such repairs?
  10. Hi Rumesh, i did last tune up when my milage was 48k. Now milage is 60k. Also when cold strt rpm sudden goes to around 2k and then comes down to 700 smthing.
  11. Hi Udaya, I have a somewht similar problem in my car - toyota premio 260. Earlier engine stopped suddenly when it was in idle state with AC on. this had happned three times upto now.. each time i felt a vibration.. in addition i think a lil unnecessary vibration exists. Also my rpm is not going above 1000 when i turn on ac when engine in idle state. ( i am used to turn ac on few minutes after i turn on engine). Did u come up with a solution?? All these happened after i gave TL to my 45k milage service where they had done a tune up.. i wonder whether they massed this up..
  12. Hi guys, I was told by someone that engine rpm should go slightly 1000 up and come down, when I start the AC in car engine idle state. My car AC does not give that nature.. After i keep some time to get the engine idle to an rpm of around 600, and when i start AC on, then rpm only goes up around 700 not upto 1000. Is this an unusual condition? P.S. I was focused on this because I have a lil bit sound and a lil vibration when AC is on. ( also my ac fan belt has tiny cracks inside going to replace it but rpm problem is not caused by it i think.) Appreciate if somebody could comment on this.. Also the car was stopped suddenly when AC is on and in idle state. It has happened 3 times. Going to hv an engine scan as well. My car is a 260 premio
  13. Guys, thanx for comments.. by a mechanical eng, i was told that if the ecu was reset, then this kind of a thing might happen, since the ecu had learned my driving style throgh forcasting based on past data.. since the ecu is now reset it will be starting to learn from the bottom and due to this kinf of things can be happen.. actually i had reset my ecu since my driving side shutter was timing mis matched.. hopefully let's think this might be the reason and if another symptom gona happen again um gona be serious on this...
  14. I am nt gng to compare since i am gng to buy a land with the rest of the money after i sell this.. anyhow i am expecting at least a near the comfort as same as premio has..
  15. Hi all, I am going to sell my premio and buy a petrol car of worth 1 million max.. what is the best car recommended? ????
  16. Hi, my car was suddenly stopped twice.. not in running mode.. once when idle mode with some ac on and the other when i reverse the car without accelerating in both these incidents rpm was very low..
  17. Hi all, Could you pls inbox me any place where we can get advanced services for toyota cars such as engine scanning and car service?? They shall let us to watch wht they r doing.. highly appreciate if anybody knows such a better place from his experience and inbox me.,
  18. Hi, Unfortunately I had two new dents on the ryt side fender of my car.. no paint damage just two small dents.. have anyone succeeded in recovering such dents???? Your response is highly appreciated... thanks..
  19. Here " car was stoppd abt 30 mins and atarted again" in da sense dat i stoped the car and started after 30 mins.
  20. Hi all, I have a premio 260 with 54000 milage. After a 60km journey car was stopped about 30 mins and was started and in idle state with parking gear and AC on. After about 10 mins engine suddnly shut down and in the meter panel the engine alarm bulb was lit in amber color. Then i started the engine again and it was started without any problem. Does anyone experienced similar? If anybody knows a possible reason what might be it???? Your comments are highly appreciated. Thanks.
  21. Nop somehow my driv side shutter base clip ( there r 2 clips by which the shutter window is attached to the moving bar) had broken. Fortunately the glass was not broken and so as the sliding kit and I was able to replace the broken clip wth a new one. B7t there was the timeout problem and after doing above I was able to fix it.
  22. Yes.. i followd abcd first but didn't work. Then followed ef. Didn't have to follow the rest.
  23. Hi TIV, Thanks a lot and it worked..... thanks a lot again my friend...
  24. I am going to follow the instructions as you posted... anyhow when i fully pull up the window untill it closes, the window comes down again since it detects the door edge as an object and goes down. Anyhow i am going to fully pull up the switch and once it comes upper edge of the door ( i.e. fully closed) another 12 seconds..
