Everything posted by ruwan67
Became Honda Lover
Dear Kim, Sorry for the delay some photos taken in the evening by my bro low Regards, Ruwan
Became Honda Lover
Thanks Nozozo, Do you know or any software so that we can jack our PC to car computer and comunicate or to see the data and program?. I think if so we can play and calibrate to get max performence. Regards, Ruwan
Became Honda Lover
Dear Friends I found why some of them got 10~11km/l. yester day I went to Jaela the figure was 10. I was shocked but finally found that my son change the AC setting to 25oC. So I change it again to 28 oC (three clicks from 25 ) and reach the 14.5km/l. I found another wonderful sensor is working while I was traveling from Jaela to Gampaha in rainy day slippery road with 55kmh the ESP (electronic stability program) So I slow down the car to40 and it switch off. I red the article about CVT gears it has infinite gear ratios ( but depend on accuracy pulley positioning actuators) so it is no need to go for 7speed auto and useful for manual gear changes. As CVT is working, the V belt grips by static friction, I thing it is not good for gear controlled slow down. Better to use breaks because replacement cost is less. However careful when you remove the batter because it erase the data in the car computer and finally bad fuel consumption. Do not remove the earth wire! Same thing will happen and check the resistance if you see any corrosions because fuel will drop down due to earth wire. I think it is better to couple good one before remove it. It is same for all CVTs. If it erased go the agent for reload. Am I correct? There are many EPS, but today the permanent magnet DC motor is coupled to steering rack so nor more hydraulic. I will check next time when it lifts. Regards, Regards, Ruwan
Became Honda Lover
Dear Friends, I found good article I-DSI Vs Vtec for fuel economy and the simply explained mechanisms http://asia.vtec.net/Series/FitJazz/lseries/ Regards, Ruwan
Became Honda Lover
Thanks Friends, I found Fit page http://www.honda.co.jp/Fit-ARIA/ While observing the km/l meter it rapidly varying just after it set to zero and variations will be reduced when the km increased. Therefore it is working like 10/1=10, 20/1.8=11.1----- 100/8.5=11.7, 102/8.7=11.7 .and in the traffic 10/1=10-> 10/2=5 (travel distance is standstill while engine burn the fule) that means it does not show the average ((max+min)/2) but the fuel consumption at any distance traveled. To rapid slowdown I reduce the gears manually while pushing the break similar to manual gear cars. I heard the same engine racing sound will it heat to gear box (this CVT) what is the best method? Regards, Ruwan
Became Honda Lover
Dear aswe There is digital meter in the car which can indicate km/l, km(both can reset at any point) and unchangeable total km run up to now (37k km when I bought it). Fuel was ¾ of tank shown by the level indicator. So I reset before the journey and the meter start with 9km/l and up counted.I start with normal auto (5 or 4 speed) and switch to 7 speed auto when I come to main road(400m). the RPM is 1500 for gear up to 4 and the designed gear change when the RPM reach to 2000. However I observe that from 5 to 6&7 want reach even 2000RPM so I change it manually to 6th and 7th (still the speed is close to 60kmh and 2000RPM), and hence speed reach to 60~65 and RPM was reduce to 1500. The same method was followed as there was few slow downs during the journey. During the journey I have not seen down movement of fuel level indicator. Unfortunately the 23km/l was reduced to 16.8km/l while crossing the city. Any way I will check the Zozo proposed method to cross check the accuracy of the meter. Regard, Ruwan
Became Honda Lover
Thanks Nozozo, The car is 2005, made in Thailand and import to Japan,1.5, i-DSI,Michulin tires, 95 Octane As per the tech instructions I thought it is 40k I do as yours. day before yesterday around 5.45AM I went to colombo from Ja-ela with zero traffic 60kmh 7speed auto the fuel economy is up to Paliyagoda 23k/l. I can you believe it or some thing wrong?. Regards, Ruwan
Became Honda Lover
Thank friends The next attractive feature is Electronic Power Steering (EPS) . Normally I don’t like power steering because it want feel the backward load of the tires and do not much return the steering wheel when you loose the hand grip while accelerating after the bend. Wow this ESP, the mechatonics guys did well job, it does the same as the mechanical steering wheel (but not very tough feeling) . I think one expert can explain the mechanism. I think like racing car this car also has high tire rotation with respect to steering wheel and it can tern quickly. When I was tern the car to avoid hole in the road (60km/h) I haven’t seen the bus is coming and the driver gave big horn I so I tern the S wheel as much as possible it works well without tire sound and jerks. Regards, Ruwan I will send the interior photos.
Became Honda Lover
Dear friends, Any how I bought a Honda fit aria though others not appreciate it. Yesterday I went to Kandy. Thanks for Honda it is the car for driving with high comfort and easy driving. Its manual and auto features help me to drive lot. When overtaking I switch from auto to manual and speed up quickly without increasing the rev (2000rpm). In the flat land I put the auto gear to sport mode WOW what a great pickup. I always keep the fuel consumption meter mode and I cannot believe it, for up climbing 16km/l and down 18km/l. I became a Honda lover though Stafford spare part price is high. Regards, Ruwan
Honda Lovers Pls Let Me Know H. Aria
I haven't bought it what worng with it? new one 2005 it say that gears can be changed from auto to manual is it true engine is i-Dsi
thanks guys once I visit the place the offer change to 2.475M, and he said it is 1.5L but the engine looks like 1.3L If you think with F15 2003 manual for 2.2M is it worth? Regards, Ruwan
Dear Honda lover I got offer recondition Honda ARIA for 2.4M pls let me know is it reasonable and the quality of the car Regard, Ruwan
T,corolla 1.6a (altis) 2004
Dear Frieds, Pls let me know the present car price & quality Regards, Ruwan
Recondition Cars Assembled In Minuwangoda
Many thanks Nilantha. I will go there and see.
Hybrid Cars, The Solution For Current Gasoline Price Hike
Dear Friends, Price of petrol is rising sky height today, and stability can not be expected even tomorrow. Only solution is hybrid cars out of green cars, I think suitable to Sri Lanka, as manufacturing of bio diesel or methanol( people will drink rather putting into tank) not possible at the moment. New Toyota hybrid can run 60~50 miles /gallon(UK) ~= 20kkm/litre. (See Yahoo green cars) Why we can request government to let tax compensation for importing it? Any one who has contact with MR can be proposed it.
What kind of a question?
Many thank for all. However no one seems happy about that?
Hi friends, I heard one keen businessmen started to assemble cars by using recondition parts import from Japan. It is locate at Minuwangoda area. Any one knows about that ?. quality, genuineness, price, future etc.
Nissan Ad Wagon
Hi Ruwan, If the has to be unregd, consider a Toyota Passo (Since the Swift is one of your options). This will be much more economical to run. The Swift is ofcourse a much better built car than the Maruti. But if you travel a lot and on bad roads, suspension repairs can crop up. Many thanks Millindu While I am searching about Toyota Passo, the model, in the internet, I found different brand like Passo X, G(1000cc), G F-PG (1300cc). All seems good. Which one is the best I mean cost, future market etc?
Nissan Ad Wagon
Many thank for the replies and valuable info. I am not a rich guy as you and not known very well about car market and cars as well. My budget is 2 million and I couldn’t found single Japanese car for the same except AD wagon. I hate Sweft as it looks like Maruthi. Ones I had a Maruthi second hand, and I loosed around rs.150k through out 2 years for breakdowns; bearing failure of the front axial time to time. So I do not even want to see it! Dear experts I expect you guidance and valuable advice!!!
Nissan Ad Wagon
Can any expert tell me about the future market of Nissan AD wagon There are few types. Which one is the best?
